hello everyone, i am really confused with some question's, i am not well with the pc hardware.
Actually i have a intel motherboard DG41RQ which has two ram slots,
here's the link http://www.intel.com/products/desktop/motherboards/dg41rq/dg41rq-overview.htm
it says that it supports, 8GBn ram memory, what does this mean, does it support 8gb for a single slot(i.e 16 gb for both the slots)?
or only 8gb for both(i.e 4 gb for a single slot). pls anyone clear my doubt,
my next doubt is that i have only 2 GB ram, i want to upgrade it, i am thinking of buying another 4 gb ram, if i buy i will have one 2 gb and another 4 gb rams, can i use two different memory ram's (i.e one will be 2gb in first slot and another will be 4gb in second slotin my pc), i am not sure about this,but i heard that we cannot use two different memory ram's(my friend said that we must use same memory ram's if u have 4 gb in one slot, another should also be 4gb). now if i buy 4 gb i will have two different memory rams. pls clear my doubt.
Kingston, Crucial and other memory manufacturers will list specific memory part numbers for the product.
Here is Kingston
http://www.ec.kingston.com/ecom/configurator_new/modelsinfo.asp?SysID=55071&mfr=Intel&...submit1=Search
Best performance results from a matched pair 2x 4GB = 8GBRecommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
Mixing RAM sizes and specifications, and sometimes brands, can cause problems. What edDV said is the safest method. And a 32bit operating system can't address more than about 4GB of RAM, so any extra would be wasted. A 64bit OS can access 6GB, 8GB or more RAM. If you have a 32bit OS, then two 2GB modules may be the best choice. If you can find a matching RAM module to your existing one, then that should work.
The OS used also has a bearing on this. If you are running XP 32bit, 2GB RAM should be sufficient. If you are running Vista or W7, 32bit, they work better with 4GB RAM.
Usually when the motherboard specifications say that it supports 8GB RAM, then that is the maximum the motherboard can address, no matter what the combination of modules.
Simple DVD to DIVX with quad core support?
By jarrodl in forum DVD RippingReplies: 2Last Post: 27th Aug 2009, 16:36 -
hardware question
By red lion in forum DVD & Blu-ray WritersReplies: 2Last Post: 26th May 2009, 13:10 -
premiere pro+mainconcept hd: best hardware setup (hdraid, cpu, ram)?
By razzta2001 in forum EditingReplies: 9Last Post: 8th Oct 2008, 07:54 -
:wink:HARDWARE QUESTION
By marcelcukier in forum Newbie / General discussionsReplies: 7Last Post: 3rd Sep 2007, 10:34 -
Hardware Question?
By Abiyad in forum EditingReplies: 1Last Post: 26th Jun 2007, 15:18
