This is going to be a tricky question as most people probably don't own both. Since similar VCR's were sold as both PAL and NTSC (with different model numbers), does the video performance that one model gives change for the different video standards?
The reason I ask is that I picked up a Panasonic NV-FJ630 (PAL) VCR and although this is a late (2002) and fairly flimsy feeling deck I am astounded at the quality. It is sharp but not grainy - and that means some processing is going on. I almost see a buffer effect but it is not obvious. Script is sharply rendered without ghosting or sharpening artefacts.
So, if this VCR has an NTSC version and it performs as per the PAL deck it is worth your time at least trying it.
It really depends on the level of VCR.
For consumer range models, it can vary highly.
For professional range models, not much variance at all.Want my help? Ask here! (not via PM!)
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 13:57 -
YCbCr 16-235 to RGB 0-255 and PAL/NTSC differences (7.5 IRE)
By intracube in forum Video ConversionReplies: 11Last Post: 5th Sep 2011, 05:39 -
Question about PAL on current U.S. Philips machines
By amckinney in forum DVD & Blu-ray PlayersReplies: 23Last Post: 1st May 2009, 21:50 -
NTSC to PAL, PAL to NTSC framerate conversion?
By Baldrick in forum Video ConversionReplies: 23Last Post: 23rd Apr 2008, 12:19 -
Quality differences on older machines?
By Ikasu in forum DVD RippingReplies: 7Last Post: 9th Sep 2007, 18:37
