Hi There,
I’m converting some DVDs into MPG2 using Roxio 10 (Convert Video option. Rip DVD to hard drive and convert from there – takes minutes). These are to be stored on a FreeAgent Ext. HDD that I have connected to my PS3. and I’m very happy with the results of the video, audio, and the time taken to convert.
My problem is:
Some of these MPG2s are over 4Gb. The HDD is Fat32, so I can’t get them on there.
I’ve tried to split the MPG2s with TMPGEnc, and the audio disappears.
I’ve tried demuxing (again with TMPEnc) and trying several different audio formats – no joy.
I’ve tried to output the individual chapters of the movie (again with Roxio) and again no audio.
I’ve tried a lengthy and convoluted process using MeGui, and I ended up with a BIGGER file size – and no audio.
My last pop was VOB2MPG – great video, no audio.
Any suggestions? I’m happy with the Video I’ve got, but is there a program where I can mux an PS3 compatible audio file onto my video?
Any other suggestions would be great. I’ve been at this for a while now.
Thanks,
Hersman.
Results 1 to 18 of 18
What format si the audio ? The PS3 will happily play AC3 form these files, but not DTS. Also, if they are commercial discs then Roxio won't be able to rip them correctly because of the copy protection. You shoul drip with DVDFab HD Decrypter or run AnyDVD in the background behind Roxio.
After you have properly ripped the disc, you can use TSMuxer to convert the file to a suitable format, and use it's automatic splitting to get FAT32 sized chunks. No re-encoding will be done.Read my blog here.
Righto - I tried ts output - no audio. I tried mt2s output - no audio. Do I have to change any settings on the PS3? All the stuff I've saved off Freeview (via PlayTV) onto the FreeAgent is mt2s and that plays fine.
OK here's the audio details - there's three types Good Roxio (Roxio that works) BAd Roxio (Doesn't work) and Good TV (Stuff recorded with PlayTV that works):
good Roxio
Audio
Format : AC-3
Format/Info : Audio Coding 3
Duration : 1h 25mn
Bit rate mode : Constant
Bit rate : 384 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Video delay : -80ms
Stream size : 234 MiB (9%)
BAd roxio
Audio #1
Menu ID : 1 (0x1)
Format : AC-3
Duration : 1h 27mn
Bit rate : 384 Kbps
Video delay : 25ms
Stream size : 240 MiB (6%)
Good TV Recorded
Audio
Menu ID : 736 (0x2E0)
Format : AC-3
Duration : 5mn 22s
Bit rate : 448 Kbps
Channel(s) : 2 channels
Video delay : -1s 171ms
Stream size : 17.2 MiB (5%)
Language : English -
Pandasoft reduced the files size (and I'm assuming the picture quality) greatly - from 5gb down to 220,000Kb
Something very odd going on with either the files, your system or your process. Pandasoft should not have re-encoded your files. I do not know what is happening at your end, but things are not as they should be. The best I can offer is that the originals did not rip correctly and still have either come copy protection, or damage from removal of the copy protection.
Read my blog here.
Will try again with other files - but I have tried with several files so far.
3D TVs compatible with PS3
By AuroEdge in forum Off topicReplies: 2Last Post: 27th Feb 2010, 08:11 -
PS3 compatible rips: settings
By ni9ht_5ta1k3r in forum Blu-ray RippingReplies: 7Last Post: 5th Jan 2009, 06:44 -
Here is how to create PS3 Compatible Files with 5.1 Audio
By pogues in forum MacReplies: 1Last Post: 5th Jan 2009, 00:30 -
Streaming to PS3...what are the specific file specs it wants?!?!
By N8theGr8 in forum Media Center PC / MediaCentersReplies: 6Last Post: 1st Aug 2008, 14:43 -
1st VOB Audio Fine on PS3, 2,3,4 VOB No Audio on PS3
By raerae28 in forum Media Center PC / MediaCentersReplies: 6Last Post: 25th May 2008, 04:10
