I have a video which is encoded in 24.554 fps which I wish to convert to 29.97 fps video without decreasing the running time (length). This is because I wish to encode it to a special format which only runs in 29.97 fps while keeping the audio intact (and if the video were to make made shorter, the audio will not synch properly).
For this, I need a program which, when changing a video's frame-rate does not simply stretch/squash the runtime but instead replicates certain frames to serve as dummy frames. I have no idea which program(s) will do that.
What format of video?
Anyway, if you can use Avisynth, for example with an AVI file you would do:
This will just duplicate some frames.Code:AviSource("Whatever.avi") ChangeFPS(30000,1001)
This will blend.Code:AviSource("Whatever.avi") ConvertFPS(30000,1001)
See http://avisynth.org/mediawiki/FPS
Or you can do it in Avidemux (can open many kinds of video, not just AVI):
Open the video, select your video format for saving (not "copy", so you can do stuff to it).
Filter/Transform/Resamplefps
Leave audio as "copy". -
It's important to say what type of "special format" you're converting to, because there maybe other considerations. For example with DVD-Video, if this was progressive , you would probably bring back to 23.976 (24000/1001) then encode and add pulldown flags for 29.97 (30000/1001)
It's also important to answer AlanHK's question on the source format, because you may get sync issues if this is variable frame rate video (24.554 fps isn't a common speed) -
The source is AVC High@L4.1 h264. The eventual target format is THP, Wii (and Gamecube) video.
Also, correction: The source file is in 24.556 fps. -
Video
Format : AVC
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 5 frames
Codec ID : avc1
Duration : 1mn 29s
Bit rate mode : Variable
Bit rate : 1 676 Kbps
Maximum bit rate : 11.2 Mbps
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16/9
Frame rate mode : Variable
Frame rate : 24.556 fps
Minimum frame rate : 19.980 fps
Maximum frame rate : 119.880 fps
Original frame rate : 29.970 fps
Resolution : 24 bits
Colorimetry : 4:2:0
Scan type : Progressive
Bits/(Pixel*Frame) : 0.074
Stream size : 41.8 MiB (97%)
Writing library : x264 core 59 r839+10 8134e7a
Encoding settings : cabac=1 / ref=5 / deblock=1:-1:-1 / analyse=0x3:0x113 / me=umh / subme=6 / brdo=1 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=1 / deadzone=21,11 / chroma_qp_offset=0 / threads=6 / nr=0 / decimate=1 / mbaff=0 / bframes=8 / b_pyramid=0 / b_adapt=1 / b_bias=0 / direct=1 / wpredb=1 / bime=1 / keyint=240 / keyint_min=1 / scenecut=60(pre) / rc=crf / crf=22.0 / rceq='blurCplx^(1-qComp)' / qcomp=0.60 / qpmin=8 / qpmax=41 / qpstep=8 / vbv_maxrate=40000 / vbv_bufsize=8192 / ip_ratio=1.40 / pb_ratio=1.30 / aq=0
Encoded date : UTC 2008-11-20 02:50:22
Tagged date : UTC 2009-05-04 04:49:22 -
This is problematic (VFR video), and you may get sync issues when converting to 29.97 CFR
You can try one of the methods above , like avidemux, but I suspect you will get sync issues that way
I would convert both the audio & video using convertfps=true . You can try it without the audio first, and just copy the audio into the new container (i.e. audio=false), but sometimes there is a slight sync issue this way, YMMV
(also, sync problems it may not be noticable for such a short video 1min29sec)
e.g.
Directshowsource("video.mkv", fps=29.97, convertfps=true, audio=true)
I don't know anything about Wii or Gamecube, there maybe other considerations as well
How to stretch longer audio stream to a shorter video stream ?
By ralf07 in forum AudioReplies: 9Last Post: 31st Aug 2011, 23:42 -
Ac3 Shorter Than Video after extraction.
By Womb4T in forum AudioReplies: 9Last Post: 18th Dec 2010, 19:28 -
Converted audio shorter than video
By rjc7394 in forum AudioReplies: 0Last Post: 15th Jun 2010, 01:14 -
Why is converted video shorter than original?
By mark86 in forum Video ConversionReplies: 1Last Post: 8th Sep 2009, 06:32 -
cutting with mpeg video wizard but making my movie longer :S
By chocolate_brownie in forum EditingReplies: 5Last Post: 18th Aug 2007, 22:45
