  1. I have burned a couple of VCDs using Ulead DVDmoviefactory but I am unable to play them in ATI mutimedia 7.1 VCD player I get the message "do not support 2.0 format"
  2. The ATI VCD Player doesn't play 2.0 standard VCD's, so is basically useless! Get one of the other software players or use media player and open the .dat file with that.
  3. I mostly do DivX, but I've played a couple of VideoCD 2.0 disks usins Windows Media Player.
    As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war."
  4. The aTi VCD player cannot play these, but the aTi file player in the same package can. Just open the DAT (I'm assuming it's a DAT file?) file with the File Player.
