hi guys, im just having problem opening MKV or MP4 files in MeGUi and VirtualDub
every time i try to open the .avs file this comes out
can anyone plz help me?[*] AVI: Opening file "C:\Users\AM\Desktop\RRR.avs"
[E] Error: Avisynth open failure:
DirectShowSource: Could not open as video or audio.
Video returned: "DirectShowSource: couldn't open file
C:\Users\AM\Desktop\MAA.mkv:
No combination of filters could be found to render the stream.
Audio returned: "DirectShowSource: couldn't open file
No combination of filters could be found to render the stream."
(C:\Users\AM\Desktop\RRR.avs, line 1)
Results 1 to 11 of 11
do you have haali media splitter + ffdshow installed?
for directshow to work, you need a working directshow splitter and decoder. What does graphstudio say when you render the file? do the pins connect?
on win7 you need win7dsfiltertweaker to enable ffdshow
or you could use ffmpegsource2 instead of directshowsource
http://code.google.com/p/ffmpegsource/ -
Windows (DirectShow) doesn't natively know what MKV and MP4 files are. You need to install DirectShow file readers and splitters for Windows to access them. Haali will work for that. Then you need DirectShow decoders for whatever codecs are used in those files. ffdshow contains decoders for all common video codecs.
yes i have.do you have haali media splitter + ffdshow installed?
and my operating system is
Windows Server 2008 R2 -
Have you enabled the appropriate decoders in ffdshow? Can WMP play the files in question? That would be the test that DirectShow filters are installed properly and working.
Also, if you are working in 64 bit Windows be aware that 32 bit programs require 32 bit codecs. 64 bit programs require 64 bit codecs. The two don't mix. -
you go easy on me sir im a noob.Have you enabled the appropriate decoders in ffdshow?
i don't have WMP, but it plays just fine on Media Player ClassicCan WMP play the files in question?
and im on 64-bit Windows
( i have installed them using K-Lite Codec Pack)Last edited by gis4ever; 7th Jul 2010 at 11:54.
MPC has it's own file reader/splitters and many codecs built it. It doesn't have to rely on DirectShow installed filters. Try disabling all of them and see if you can play the files:
View -> Options -> Internal Filters... uncheck all the source filters and transform filters. Exit MPC and restart it for the changes to take effect.
You may want to note which are enabled so you can reenable them after testing. -
Instead of fiddling with your directshow filters/splitter and trying to get them to work, you can use ffmpegsource2 as suggested above (alot easier, and more consistent, because directshow isn't necessarily frame accurate, and can vary from system to system depending on what filters you have installed)
yes copy the ffms2.dll and ffms2.avsi to the aivsynth\plugins directory
the syntax for both audio & video is
ffmpegsource2("video.mkv", atrack=-1)
or
vid=ffvideosource("video.mkv")
aud=ffaudiosource("video.mkv")
audiodub(vid,aud)
MkvТоMp4 v0.224 - rapid tool for repack Mkv to Mp4
By oreons in forum Video ConversionReplies: 808Last Post: 7th Mar 2022, 02:43 -
MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
By Baldrick in forum Newbie / General discussionsReplies: 55Last Post: 29th Jun 2012, 12:19 -
Pixelation on mkv, mp4 and avi files
By ajkrishock in forum Newbie / General discussionsReplies: 10Last Post: 24th Nov 2010, 07:12 -
Problem Opening h264 in VDubMod [MKV - XviD Conversion]
By catastrophe in forum Video ConversionReplies: 3Last Post: 1st Jul 2010, 19:13 -
Xvid4PSP .mkv file opening problem
By hibbs in forum Video ConversionReplies: 2Last Post: 23rd Mar 2010, 19:56
