Hi,
I have used MakeMKV to rip my blu-ray dvds to an external HDD with no problems at all.
The issue is that when I play these MKV files using my PC or laptop (on AC power), I have no issues wit playback.
When the laptop is on battery, then the playback is choppy and the sound is horrible and the movie becomes unwatchable.
Any idea why is that? I need to be able to watch these during long flights.
My guess is that the CPU is stepping down to use less power and save battery life. Playing bluray quality video is very taxing on a system. It may also step down HD speed as well. Never heard of that happening but it cause problems as well.
Try using MPCHC so it uses (if possible) any onboard GPU. You could also go into the power config and keep everything at full power when on battery. Good luck getting through a whole movie though...Have a good one,
neomaine
NEW! VideoHelp.com F@H team 166011!
http://fah-web.stanford.edu/cgi-bin/main.py?qtype=teampage&teamnum=166011
Folding@Home FAQ and download: http://folding.stanford.edu/
Newbie question about blu ray ripping and converting
By pete7769 in forum Blu-ray RippingReplies: 8Last Post: 12th Jan 2012, 16:02 -
Blu Ray ripping container & codec question.
By jamesj84 in forum Blu-ray RippingReplies: 10Last Post: 15th Dec 2011, 12:18 -
Question about ripping blu ray?
By HIimHISH in forum Blu-ray RippingReplies: 1Last Post: 21st Apr 2011, 16:21 -
Beauty&Beast Blu-Ray Ripping Loses 3-Dimensionality after ripping
By KostaRae in forum Blu-ray RippingReplies: 4Last Post: 22nd Mar 2011, 04:50 -
blu-ray to mkv => using MakeMKV - Subtitles not visible...
By metagol in forum Newbie / General discussionsReplies: 2Last Post: 22nd Jul 2009, 14:36
