Hi.
I have the latest MPC-HC (installed with k-lite mega codec pack this time, previous times I installed it on my own from their website).
MKV files (720p) doesn't work as they should with MPC.
When I open a mkv file, it plays ok for a few seconds but then it becomes slower and slower and slower and the cpu usage rises really fast and finally I have to close mpc-hc through task manager.
BUT, these files do work with Windows Media Player without any problem.
Latest K-Lite Mega Codec Pack is installed. (I understood that installing k-lite or any codec pack isn't a good idea only after reading few topics here today when searching for similar problem to mine, so next time I won't install it).
Latest drivers are installed.
Filters settings: http://i50.tinypic.com/2vbucer.jpg
So I have 2 questions:
1. How to make mpc-hc play these mkv files smoothly as it did before I did a fresh install of Windows (1 week ago)?
2. I want to know why k-lite codec pack or any other codec pack isn't recommended. Also, I would like to know how to play files without codec packs. Playing video with MPC-HC is understandable as it have it's own codecs (right?), but audio files I prefer playing with windows media player, so FLAC and other formats won't work by default.
Thanks, waiting for your answers![]()
Hit search Codec Pack Problems, read. There are millions of posts and problems caused by these, they are not recommended by anyone who knows what they are talking about.
Codec Packs throw a whole load of codecs at your system without knowing what they are doing, what they are going to be used for etc. They are constantly giving users issues with conflicts between codecs, usually between what they have added plus what you have on your system, but some are even so terrible that the codecs within the pack itself can conflict with each other. They are difficult to remove, as by nature they put things all over your system, meaning that even after you've uninstalled and removed everything you could find, it can still be there causing conflicts. They are the equivelent of feeling ill and going to your doctors and saying, i'll just have some of all the pills, hoping that one of them will make you feel better.
Much more accurate would be to look at the files that your trying to play with something like mediainfo, work out exactly what your dealing with, if you need to download a codec, find it, get it on its own so you know what you've got and theres no risk of messing up other things that currently work fine.
I'd advise restoring PC to pre-codec pack and starting again. -
Thanks for the quick answer, I now know what to do with codecs next time I install windows.
But, I wasn't planning reformatting windows now because of this problem, is it really necessary?
Nothing else to do? :\ -
Have a good one,
neomaine
NEW! VideoHelp.com F@H team 166011!
http://fah-web.stanford.edu/cgi-bin/main.py?qtype=teampage&teamnum=166011
Folding@Home FAQ and download: http://folding.stanford.edu/ -
Pull! Bang! Darn!
extract subs from MKV -- MKVextract doesn't work
By AlanHK in forum Video ConversionReplies: 4Last Post: 9th Dec 2011, 22:47 -
Need Help. I Can't See Subtitle When Playing Mkv File With MPC
By skyrocks in forum SubtitleReplies: 0Last Post: 26th Jan 2009, 14:59 -
No subtitles when playing a .MKV file in MPC HC
By THX-UltraII in forum SubtitleReplies: 5Last Post: 21st Aug 2008, 07:08 -
playing .MKV file in MPC Home Cinema, no subs
By THX-UltraII in forum Newbie / General discussionsReplies: 1Last Post: 15th Aug 2008, 07:22 -
Playing 24p MKV files with MPC, haali and ffdshow.
By Phorze in forum Media Center PC / MediaCentersReplies: 5Last Post: 13th Aug 2007, 17:41
