    May 2001
    Scotland
    Hi all,
    My dad bought a new all in one PC (hp touchsmart) it has no firewire ports and no way of adding a pci card.
    Is there any way he can capture the video from his DV camcorder on this pc?
    Cheers,
    Steven
  2. Member M Bruner's Avatar
    Oct 2008
    Have you looked into a firewire to USB converter?
    There are no problems - only chances to excel.
    -- Unknown
  3. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    I can't vouch for how well it works, but you would be looking for something like this " http://www.everythingusb.com/news/index/3889.htm
    There seem to be a few around, but check to make sure they support your format (I assume it is PAL)
    Read my blog here.
    May 2001
    Scotland
    that looks like the very thing, just need to find one now.
    cheers
    May 2001
    Scotland
    can only see ntsc ones, although Pinnacle do a Movie Box HD-USB, that looks like it does dv to usb transfers.
  6. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    Those Pixela devices don't work well. For full quality capture to another computer that has a Firewire port.
    Or, capture analog to an S-video capture device. The quality will be lower.
    http://www.kiva.org/about
