Hello,
I have a Dell Inspiron 910 mini. It has Ubuntu Linux operating system on it. I would like to put XP. Can I do this through a USB thumb drive? It has no cd drive. Here are the specs. Also it only has 8gb hard drive..... is that enough for XP? I have read where some have ran XP on these but don't know how.
1W959FPRC,N270,1.6,512KB,DMV,C01H510GGDE,PROD,INFO ,SERI,ENG,WW1G383GGDE,PROD,INFO,WSI,ENG1U943PTSH,D RIVER DOWNLOAD,ENG1H840JTSH,UBUNTU,ENG1Y877GAssembly,Ada pter,Alternating Current,30W,2P,United States 9101M770HGuide,SETUP,Inspiron,910,English1M958HKey board,61,United States English,Single Pointing,Qiao Hong,Windows1C901HBattery,Primary,32WHR,4C Lithium,Simplo1P896HKit,Software,UBT8.04+,910 Media1Y614GLiquid Crystal Display,8.9WSVGA,Light Emitting Diode,True Life,Lg Philips Lcd1G558JAssembly,Cable,Low Voltage Differential Signaling,WO/CMRALCD,9101J141HASSY,BASE,NBK,WO/WWAN,9101N204HCard,Wireless,Minicard Broadcom Corporation,ARCD United States1PP102Dual In-Line Memory Module,1G 800,128X64,8,200,1GBIT1D154HSolid State Drive,8G,Parallel Advanced Technology Attachment,4GX2,STEC1N302HBezel,Liquid Crystal Display Silver,8.9,WO/CMRA,9101Y173MAssembly,Cover,Liquid Crystal Display,IMR,BLUE,Wireless Local Area Network Card,
http://www.ocia.net/articles/xpflashdrive/page1.shtml
http://discuss.pcmag.com/forums/thread/1004417525.aspx
http://www.eeeguides.com/2007/11/installing-windows-xp-from-usb-thumb.html
Hope these links help. FYI, its way easier to install Windows 7 on it. Although, you'll need a bigger HDD -
Depending on how much you put on it 8BG may or may not be enough space. I first installed WinXP last fall which occupied 6.2GB with the programs I have, but that's grown to 10.5GB with all the Windows updates. Also keep in mind at least 15% free space is recommended to run Defrag. IMO 8GB isn't large enough for WinXP unless you have very few programs installed. FYI my system is dual boot with Win2k which occupies just 4.2GB with all updates and all the same programs installed. You might consider either going with Win2k or getting a larger drive. BTW Win2k support is scheduled to stop on July 13 if memory serves, i.e. no more Windows updates, patches, etc.
I have an Asus netbook that originally had a 4GB HDD. The original eePC linux distro was good at downloading updates, etc - to the point that it filled the hard disc (SSD). I did upgrade to a 32GB SSD, and changed the OS to eebuntu. It made a huge difference! It takes up far less space, has plenty of apps and games, connected to the internet, etc..
I have a Plextor external drive that I connect for upgrades, etc.. (we have four netbooks in the house).
I did see a refurb drive at newegg today for $25 after rebate (on slickdeals.net and dealcatcher).
I hope you're lucky enough to get it to run. BTW: I'm pretty certain XP will try to install tons of updates, and may even fill up the 8GB SSD.;/ l ,[____], Its a Jeep thing,
l---L---o||||||o- you wouldn't understand.
(.)_) (.)_)-----)_) "Only In A Jeep"
How to Cut & Merge mini 10 part mini series?
By skorpinok in forum EditingReplies: 5Last Post: 8th Oct 2011, 09:41 -
Capture progressive mini-dv tape on interlaced mini-dv cam ?
By alip in forum Capturing and VCRReplies: 4Last Post: 8th Feb 2011, 17:27 -
Hardware choices: standalone mini-DV deck, or cheap mini-dv camera?
By SgtRauksauff in forum Newbie / General discussionsReplies: 3Last Post: 14th Oct 2008, 02:18 -
Dell or imac
By fairytale00 in forum ComputerReplies: 17Last Post: 29th Mar 2008, 12:51 -
Hd Mini dv tapes via SD mini DV camcorder
By imptech3 in forum Newbie / General discussionsReplies: 1Last Post: 13th Jul 2007, 02:11
