Hello,
Something entirely new for me, want to make a DVD from an AVI uncompresses(Lossless) 14 Gigabytes and make a DVD.
Tools I have are
Nero suite,
CS4,
Ive looked around a lot in cs4 ,premiere pro, Adobe Encore but Im finding it quite difficult.
Original AVI was created in After effects and saved Lossless,I have also a Qtime version based on lossless.
I would really apreaciate a nudge or two in the right direction to get me started
p
https://www.videohelp.com/tools/TMPGEnc
This will get you to MPEG2....then you need to author the DVD.
Your Nero package will probably do it too. -
avstodvd is another option. I'm nearly certain it should handle uncompressed avi. It does do hd mpeg so I would assume it can do easier to handle uncompressed avi. Worth a shot and its free. It uses either hcenc or quenc to do the mpeg encoding.
multiavchd is another option is as well. However again I am not 100% it handles uncompressed avi.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
I'd recommend FAVC from that list of All-In-One converters if you're just looking for something simple. It doesn't get much simpler than that program.
Although, shouldn't Nero be able to make DVDs based on source files? I haven't actually used Nero in years, but I remember that I used it to do just that before because I've got the DVDs I made sitting right next to me.
What is uncompressed AVI?
By andrewjameshoward in forum Capturing and VCRReplies: 35Last Post: 2nd Nov 2012, 08:56 -
Convert uncompressed avi to DVD
By sastek in forum Newbie / General discussionsReplies: 2Last Post: 28th Apr 2011, 22:47 -
Exporting from uncompressed AVI to uncompressed MOV
By courtneye in forum Video ConversionReplies: 0Last Post: 9th Jul 2010, 09:20 -
MOV to Uncompressed AVI
By sdiddy in forum MacReplies: 11Last Post: 8th Mar 2008, 10:10 -
.rm to uncompressed avi on OSX?
By midnightraver42 in forum MacReplies: 15Last Post: 10th Nov 2007, 15:01
