Not sure where this kinda of question should be posted since it's not directly about audio. I'd have asked this on the Doom9 Forums since they have a section for AVISynth, but I just registered their today and you have to wait 5 days to make threads.
Anyway, I use AVISynth and VDub to do as much of my converting as possible. I have a TON of files that need to be converted and as a result I've made a very basic program in Java to make AVS files for me. With my variety of files naturally comes a variety of video/audio codecs used. Haven't had any trouble with video codecs and VDub so far, but audio has been somewhat of an issue. I'm able to get it all working, but many times I end up having to do things manually when it comes to setting up the audio in the AVS files. So, my question is this. Is there any way in AVISynth to have it detect what kind of audio is used in a video file? I'd rather not have to find out this information manually if I don't have to.
It depends what source filter you are using, and the type of file. For example AVISource won't open MKV containers
You can specify audio in the script if you want. Some source filters do not specify audio and you could combine using audiodub().
FFMS2 will open most types of files, and if you use the defined function ffmpegsource2, specifying atrack=-1 will use 1st audio track
You have to be more specific (i.e .post information on the specific files, and your script used) if you want more specific help
BTW, there are avs batch scripters available -
I'm sure there are AVS batch scripters out there. I've never checked because I just felt like making one myself. Helps me with my Java programming.
I thought I asked a pretty straight-forward question already and don't see how posting any of what you request is going to make any difference because it's something I don't know. All I'm wondering is if there is a way in AVISynth to determine how many audio channels are in an audio source so that I can then specify how to downmix it? I use DirectShowSource currently to open all of my files, MKV, MP4, OGM, AVI, and whatever else I have. Almost all of the audio sources I've come across have been AC3 so if what I'm asking can't be done across any audio source then would it be possible with just an AC3 source? To be even a bit more specific, it's coming from an MKV file, though I'm sure I have a few other files types that'll have 6-channel AC3. -
AudioChannels(clip) returns the number of audio channels.
http://avisynth.org/mediawiki/Clip_properties -
Now that is exactly what I was looking for.
Very useful. Now I won't have to manually specific how the AVS file should handle the audio track.
Thanks for the help. -
FadeIn/FadeOut (Avisynth) question
By Cherbette in forum EditingReplies: 5Last Post: 20th Jan 2012, 22:27 -
Avisynth Script Question
By MegaTonTerror in forum Video ConversionReplies: 4Last Post: 22nd Aug 2009, 22:28 -
CCE, AviSynth and MP4 Question
By Maikeru-sama in forum Video ConversionReplies: 5Last Post: 31st Mar 2008, 12:19 -
MKV, CCE and AviSynth Question
By Maikeru-sama in forum Video ConversionReplies: 10Last Post: 14th Jan 2008, 17:35 -
Avisynth-Tweak color-question
By SerbianBoss in forum EditingReplies: 4Last Post: 9th Sep 2007, 10:30
