Hello,
I have a Radeon 4870 that captures great video from my game using Fraps 3.0.1. It makes a very clean beautiful AVI
I then use Studio 14 OR Adobe Premier CS3 to trim the clip. I attempt to save or export the clip to HD AVI.
The quality degrades significantly and the resolution of the trimmed clip is extremely fuzzy and poor.
Why is this?
thanks!
japentz
Results 1 to 9 of 9
Hello! thanks for replying.
I believe Fraps uses its own codec called Fraps FPS1 codec
I was thinking it might have to do with the codec. Windows media player plays the original AVI beautifully.
Is the codec the problem and is there a free codec coverter somewhere?
As far as the edited clip I'm not sure how to set the codec in either Adobe Premier or Studio 14 or what they use.
Thanks!
japentz -
Hello, I am not sure how to tell what either Studio 14 or Adobe Premier uses. I also tried in simple Windows movie maker (terrible I know).
In all three there was a major degredation of quality. How do I tell what codec they use?
thanks again.
Use a better export format, like uncompressed AVI, but filesize will be huge .
Use the same resolution as the input (ie. don't downscale) -
That sounds like "Microsoft Video 1" with the fourcc "CRAM"? That's an antiquated codec. Don't expect a lot out of it.
Also be aware that most high compression video codecs use the YUV colorspace and encode colors at 1/4 (1/2 each dimension) the resolution of the grayscale information. So small colored objects get blurry, especially if on a colored background as well. See the sample image in this post: https://forum.videohelp.com/threads/315040-Focus-question?p=1948777&viewfull=1#post1948777
Video Resolution on newly created .wmv - Poor
By whitey218 in forum Newbie / General discussionsReplies: 5Last Post: 4th Oct 2010, 18:52 -
best audio video quality of youtube poor quality and not hq flv videos.
By nusratjaveid in forum Video ConversionReplies: 3Last Post: 20th Jun 2010, 19:23 -
Poor Video Quality
By itsernst in forum Capturing and VCRReplies: 20Last Post: 10th Feb 2010, 16:32 -
avi to dvd picture poor quality
By dwilson in forum Authoring (DVD)Replies: 2Last Post: 21st Mar 2009, 08:10 -
Low quality video on high resolution screen, improve video quality?
By Nitrius in forum Software PlayingReplies: 4Last Post: 29th Dec 2008, 13:38
