Dear All,
First posting so please bear with me. I am thinking about buying a Sony BDP-S370 Blu-Ray DVD player. I notice in the hacks section that it states you need to use a OneForAll URC-7950 remote to make it multi-region. Never had to buy anything to do this in the past but is it referring to...
http://www.play.com/Electronics/Electronics/4-/9188865/One-For-All-URC-7950-Comfort-Li...l/Product.html#
Thank you for your help.
Paddy
Should have added that I realise this will only make the DVD multi-region and not Blu-Ray. That is all I want.
Paddy -
Hi. My 1st post. The remote that came with my SONY BD-S370 is the B107A; I don't know where the 'magic' button is located
Sony BDP-S370: .mkv Playback Problems
By MWisBest in forum DVD & Blu-ray PlayersReplies: 8Last Post: 11th Jan 2017, 00:54 -
Profile Format High@L5.1 Not supported by Sony S370 BDP - Help
By whALL in forum DVD & Blu-ray PlayersReplies: 1Last Post: 21st Jan 2012, 12:43 -
Does the Sony BDP-S370 play DVD+R discs?
By MJ in forum DVD & Blu-ray PlayersReplies: 6Last Post: 4th Dec 2011, 03:38 -
Sony BDP-s370 hack problem..
By manicjon in forum DVD & Blu-ray PlayersReplies: 1Last Post: 10th Jan 2011, 08:41 -
Can't play DVD+R on Sony BDP-S370
By sconepanman in forum MacReplies: 8Last Post: 2nd Dec 2010, 14:42
