Hi
I currently live stream 720p video game console footage from my Black Magic Intensity using VH Multicam for shows I do on the net. My shows are usually 2 to 3 hours long.
I'd like to start recording some of this footage locally in good quality. I tried using VH Capture to record the footage but run into some issues.
- uncompressed footage records great, but produces 3 gig files every 30 seconds.
- selecting other codecs like divx oddly only record 1 second of footage before it stops writing to a file. codecs like xvid just freeze up.
Is there another piece of software or codec I should be using to record video?
I am running windows xp 32 bit with a 2.6 ghz i7 cpu, I have a 1TB drive dedicated for video footage.
Thanks!
Actually, I just tried recording it as an mov with a high bitrate and it seems to be performing pretty well with a reasonable file size.
I'd still love to hear any suggestions, thanks!
Suggestions on how to record live video to hard drive
By bnchs in forum Video Streaming DownloadingReplies: 5Last Post: 29th Aug 2009, 12:38 -
How to record video from camcorder and stream live simultaneously
By bnchs in forum Video Streaming DownloadingReplies: 2Last Post: 27th Aug 2009, 13:28 -
How to record live radio and video streams?
By Shadowofthedarkgod in forum Video Streaming DownloadingReplies: 8Last Post: 15th Aug 2009, 19:40 -
How do i record CNN Live video streams?
By quantass in forum Video Streaming DownloadingReplies: 4Last Post: 13th Sep 2008, 11:44 -
Can you record live while also backing up the video to a dvd recorder?
By Todd3353 in forum MediaReplies: 1Last Post: 26th Aug 2007, 23:33
