Hello,
I have joined the forum because I have trouble understanding how to use my LG DVB-T HDD/DVD Recorder.
I can record things from tv and then burn onto a dvd disk, but wondered if I can plug my old VCR machine into the Recorder, and transfer a home video on cassette from there onto my HDD/DVD machine and then burn a copy?? Anyone know if this is possible?
CelticVoice![]()
I did this a long time ago.
All I did was connect the vcr to the tv and set the input to line one.
I then hit "play" on the vcr and "record" on the dvr.
Give it a try. -
Thanks for the quick reply. Our DVD/he'd machine is a RH2T80 model. Would it work with that one?
Thanks, cv -
It should work with any dvd recorder.
When you set "record" you have to set input of vcr-usually line 1.
Hope this helps.
You can also call LG for help.
They are a great company for customer service.
800-243-0000Last edited by Psco2007; 4th Jul 2010 at 15:21.
Just realized you are from Australia.
Here's a link for you to get more info and contact LG:
http://www.lg.com/au/general/contact-us.jsp
Reading HDD from HDD recorder on Windows XP
By mvidelgauz in forum Newbie / General discussionsReplies: 12Last Post: 18th Apr 2011, 02:51 -
Copying from standalone hdd recorder's hdd to pc hdd
By flez in forum ComputerReplies: 7Last Post: 6th Dec 2010, 06:17 -
Which HDD DVD recorder the best ?
By come_mon in forum DVD & Blu-ray RecordersReplies: 14Last Post: 23rd Nov 2010, 21:45 -
PC HDD Driver for Panasonic DVD Recorder HDD
By SG-01 in forum DVD & Blu-ray RecordersReplies: 9Last Post: 30th Aug 2007, 03:54 -
Toshiba RD-KX50 DVD Recorder / HDD Recorder
By Kinddomaker in forum DVD & Blu-ray RecordersReplies: 2Last Post: 2nd Jul 2007, 21:19
