    Mar 2009
    Hi all,
    I have been using CapDVHS for some time now to record HD shows off my DVR. I use the 'Timer Reserve' option quite a bit and I've noticed that ocassionally when a program has finished recording that my DVR shuts off. I have the 'After' option set to 'None' but it still shuts off my DVR and then if I had reserves after this they won't record obviously. Any solution to this that you know of?
    Thanks in advance!
    dbanimal
    Mar 2009
    Anyone with experience with this?
    dbanimal
    Not me. Nope, sorry. (Just wanted to reply -- people are reading, we just don't have answers for you.)
    Feb 2008
    Check/uncheck the correct checkboxes in the settings.
    Click the "Setings" tab.
    CHECK "Video Power On at Capture Start"
    UNCHECK "Video Power Off at Capture Stop"
    UNCHECK "Does not Video Power On at reserve"
    CHECK "Does not Video Power Off at Reserve"
    Mar 2009
    Awesome!! Thanks for this helpful info!! I will give it a shot when I get home.
    dbanimal
