I have a LG blu ray player and I converted most of my mkv files to divx using SUPER and Divx Plus Converter. The files work perfectly on my ps3 but not on my blu ray player because there is always an error that says file is larger than 720x576, but I can play my other hd avi files that I download on my player and not the converted files. Anybody have a solution?
Can you post the details from the hd avi files that works? Video and audio codec, resolution, bitrate, etc.
And what settings are you using in super and divx plus converter? -
The player may be limited to 720x576 when playing Divx/Xvid files even though it is capable of playing HD h.264 video. That is not uncommon.
the specs for the files that work are: Type.................: Movie
Video Format.........: AVI
Video Bitrate........: 3028Kbps
Resolution...........: 1280x528
FPS..................: 23.976
Audio Format.........: AC3
Audio Bitrate........: 256Kbps 6Channel 48000Hz
Source...............: Blu-Ray
Genre................: Action | Adventure | Sci-Fi
Length...............: 126 Minutes
IMDb Rating..........: 8.0
Movie Information....: http://www.imdb.com/title/tt0371746/
File Size............: 2.96 GB
another is: ||--- Source: BluRay x264
||--- Encode: XviD 3191kbps 23.976 1280x544
|| AC3 640kbps 5.1chan 48kHz
and the setting I use are avi divx with ac3 audio. I copy the audio and reencode the video. -
Can i burn avi/mp4/mkv etc to blu ray media and play it in a blu ray player
By brad350 in forum Newbie / General discussionsReplies: 10Last Post: 21st Apr 2012, 05:15 -
Wanna convert Blu Ray Movie to Play on Laptop/PC without a Blu Ray PLayer !
By augustya in forum Blu-ray RippingReplies: 5Last Post: 13th Aug 2011, 04:35 -
Copyed Blu ray won't play in blu ray player
By gweedow in forum Video ConversionReplies: 6Last Post: 13th Jan 2011, 15:58 -
What is the difference between a Netwrok Blu-ray and Blu-ray DVD player?
By coody in forum DVD & Blu-ray PlayersReplies: 1Last Post: 4th Sep 2010, 23:04 -
My Sony Blu-ray player BDP-S1 does not recognize my Blu-ray Disc
By showgirl in forum Newbie / General discussionsReplies: 5Last Post: 2nd Oct 2007, 13:48
