  1. My Nec writer didn't cause me any problems and was working perfect for 3 or 4 years until yestarday...
    I have to write a big Led Zeppelin concert in two DVD9 Disks, i buy one Verbatim and one Maxell, both DVD+R DL
    The Verbatim disk was written perfect, but when i put the Maxell the recorder didnt recognize it, and the BurnAware couldn't start, the recorder opened and i was prompetd to insert a DVD+/-R DL...
    i upgrate my firmware - nothing
    i download DVDFab 6 and it manage to write the second half of the concert but still i cant read/open it, on my sister laptop the disk is runing allwright...
    If you can help me i will be the happier thing in the Solar system, thanks
    long live R'n'R
    p.s. sorry for the bad english
  2. Member classfour's Avatar
    The Heartland, United States
    Use only good quality Verbatim DL media, most out there otherwise is crap.
    Use imgburn to burn - don't crank up the speed, take it slow.
    ;/ l ,[____], Its a Jeep thing,
    l---L---o||||||o- you wouldn't understand.
    (.)_) (.)_)-----)_) "Only In A Jeep"
  3. Is there any way to make my NEC read the Maxell DVD ?
  4. Member classfour's Avatar
    The drive isn't seeing it for some reason. NEC's aren't the best readers - I have Sony Optiarc drives in my desktop machine, they suffer the same problem on some discs. I keep an old Panny drive (best reader that I own) in an external enclosure for just that possibility.
