Hi. I was playing with some fillters/codecs and could get it right.
I'm using MPC-HC with ffdshow and CoreAVC. What I want is to set the "System Default" renderer to Haali.
If I choose "Haali Renderer" in the output of MPC-HC then ffdshow doesn't start up, only CoreAVC.
When it is set to system default ffdshow and CoreAVC start but then I can see that the quality of the picture (when resizing it) becomes pretty bad compared to Haali.
So I checked with graphstudio and the video renderer is VMR. If i remove it from the studio and put Haali instead it all works correctly with ffdshow and CoreAVC and I get good quality with everything I want.
I also tried changing the merit of Haali video renderer to the maximum. didn't help.
That's how it is now: http://img37.imageshack.us/img37/8402/craphe.png
How I want it to be: http://img52.imageshack.us/img52/8210/goodk.png
If you need more info I'll be glad to provide everything I can.
Hope you can help.
Results 1 to 1 of 1
HELP changing default settings in Vegas
By TKB in forum Newbie / General discussionsReplies: 0Last Post: 16th Jun 2011, 01:04 -
Pixelated videos - Is there a way to change the default renderer?
By klischee in forum Software PlayingReplies: 6Last Post: 29th Oct 2010, 18:21 -
Haali renderer resizes video
By Ollielufti in forum Software PlayingReplies: 4Last Post: 31st Aug 2010, 15:03 -
Setting Default DirectX Video Renderer
By Ace-Of-Spades in forum Software PlayingReplies: 3Last Post: 30th Nov 2007, 11:31 -
Changing DeVeDe default settings
By henrik.uggla in forum LinuxReplies: 0Last Post: 25th Jun 2007, 14:29
