How do I use ImgBurn to write an .avi file to a DVD-R so that it will play in a standard DVD player?
If you want something totally free, also have a look at AVI2ISO
It converts AVI and MKV back to DVD ready to watch in a standalone, and has the ability to use AVISynth to add a lot more power and functionality to the conversion
I personally use ConvertXtoDVD v4.xx, the quality doesn't match HCEnc but 'they' refuse to add support for 3rd party encoders. Its better than most AVI converters and also handles virtually any video file you give it. It handles full resolution MKV's 1920x1080p a lot better than anything else, keeps audio pretty much in sync all th etime and can also burn to DVD when completed
Can also convert 2 channel AVI's to 5.1 sound, and it does work as the difference is very noticeable on our standalone with surround sound set-up when the 2-channel AVI is compared to the 5.1 conversion on DVD
Its not quick when converting full MKV 1920x1080p blu-ray sources to DVD specs, but it has a hell of a lot of work to do, on my Q6600 running at 3.2ghz it takes about 1-2 hours to convert the MKV, but the final quality is better than DVD sources -
IMGBurn also will NOT convert an AVI, its purely for burning discs, DVD or CD, which its very very good at
I use it for all my DVD, data CD and also my X-Box 360 and Wii 'backups'. It can also burn audio CD's but found it gave me problems so use Easy CD-DA Extractor for my audio CDs
IMGBurn produces very high quality and compatable burns when compared to other burning software I have used in the past. Speed is NOT everything when you are burning discs. Quality is what counts. I burn at x8 for 99% of everything but use x16 media on the reasoning that the quality control is higher to produce x16 media so burnng a notch down should give guaranteed results 99.5% of the time ... which is usually does. Unless I screw up, its very rare I get bad burns, but also do NOT buy 'bargain' media
Pay that little bit more and save time and aggrevation later when you can't watch your films or have go out and buy better media and burn it all again -
That is always sound advice; I only use Verbatim discs, most drives are calibrated for them. You don't have to pay extra to get quality media, just wait for sales and stock up according to your usage so you can last until the next sale. As for burning slower, the speed is dependent on the media and the drive. With todays high speed drives, 8x might not produce the best results. I've seen tests where using the disc's speed was better than the slower speed. Check out CDRLabs, they have nice in depth reports on drives.
help me how to make a set of avi files to DVD with menus of each avi file
By mmah in forum Video ConversionReplies: 5Last Post: 9th Mar 2011, 03:07 -
DVD file too large to burn to disc..how can I make it fit?
By Natalie88 in forum Newbie / General discussionsReplies: 4Last Post: 18th May 2010, 09:14 -
Can you rip a blu ray file, make edits, and put it back onto the same disc?
By FatalX in forum Blu-ray RippingReplies: 6Last Post: 24th Apr 2010, 17:49 -
How to make one .avi from a two disc set?
By TheMoreYouKnow in forum Newbie / General discussionsReplies: 8Last Post: 24th Sep 2009, 09:52 -
What label settings / file restrictions to set for ImgBurn for AVI files?
By Relayerman in forum Software PlayingReplies: 2Last Post: 14th Aug 2009, 23:22
