  1. Hi, all
    I'm new to video and a bit confused, i want to shoot video that will be mostly uploaded to the web, i have a camcorder that shoots interlaced, however, looking around it seems i should be shooting in progressive for web video as converting interlaced to progressive will effect video quality.
    Any advice would be appreciated!
    Regards
    Rank
    Oct 2005
    666th portal
    computer monitors are progressive so yes it is easier and will result in better video if it is shot progressive. time for a new camera?
  3. Banned
    Jul 2010
    Poland
    Disagree,
    shot interlaced, then use deinterlace while conversion and you have 50/60p instead of 25/30p.
  4. Disagree,
    If you do that you're removing half your temporal video info. If its just for the web, shoot progressive.
  5. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    Originally Posted by videopoo View Post
    Disagree,
    Depends how you deinterlace. Bob* and various motion adaptive modes produce a 59.94p result.
    If picture quality and large screen display aren't an issue now or in the future, shoot 30p (29.97p actually). 30p is good for today's web uplink and for certain effects modes where the picture element will be composited into a larger frame.
    * a pure Bob has flicker or shimmer issues for low motion frames. Smart deinterlacers switch modes on a pixel block basis based on motion vectors.
    http://www.kiva.org/about
