Results 1 to 24 of 24
    Jan 2008
    I'm thinking of getting this http://www.newegg.com/Product/Product.aspx?Item=N82E16822136593 but I just have a few questions.
    Does it really play every MKV, x264, H264 files? I have a horrible PC and can't really encode anything. I usually try to play everything on my 360, which really doesn't play much, the 2ch audio really limits everything and does not play any MKV file.
    I just want these questions clarified before I make my purchase.
    Thanks.
  2. Member classfour's Avatar
    The Heartland, United States
    Why would Western Digital lie?
    I suspect it depends on the precision of the encoding - much like any video player.
    ;/ l ,[____], Its a Jeep thing,
    l---L---o||||||o- you wouldn't understand.
    (.)_) (.)_)-----)_) "Only In A Jeep"
  3. It does not play flv or swf files...I think.
  4. It plays .mkv x264 H264 containers with no problems. Plays any DVD/Bluray rip I throw at it.
    Does not play .flv files
    Plays most .wmv files, but not all.
    Even plays .mov files surprisingly.
    A handful of .mp4 files have given me problems such as unable to search, and occasionally jittery playback, but the problematic files all were downloaded from the same source, so it's possible those files are corrupt themselves.
  5. And it wont play RMB files? which AFAIK are used extensively for anime in the Oriental countrys.
    And it cant be used with bbc iplayer neither
    The electronic components of the power part adopted a lot of Rubycons.
  6. Originally Posted by RabidDog View Post
    Oriental countrys
  7. Member Soopafresh's Avatar
    Jan 2004
    Not DV
    "Quality is cool, but don't forget... Content is King!"
  8. Read a detailed review which also tests to find out what it does and does not play:
    http://www.anandtech.com/show/3830/wd-tv-live-plus-western-digitals-latest-media-player-reviewed
  9. Member crazy14muzic's Avatar
    Jan 2005
    USA Missouri
    My WD box with firmware 1.03.22 plays flv files fine.
    flv file details below.
    General
    Complete name                    : C:\downloads\New Folder\demo.flv
    Format                           : Flash Video
    File size                        : 52.1 MiB
    Duration                         : 20mn 18s
    Overall bit rate                 : 359 Kbps
    Tagged date                      : UTC 2009-02-19 17:36:19
    Tagging application              : flvtool++ (Facebook, Motion project, dweatherford)
    totalframes                      : 36527.000
    Video
    Format                           : AVC
    Format/Info                      : Advanced Video Codec
    Format profile                   : Baseline@L3.0
    Format settings, CABAC           : No
    Format settings, ReFrames        : 1 frame
    Muxing mode                      : Container profile=Unknown@3.0
    Duration                         : 20mn 18s
    Bit rate                         : 288 Kbps
    Width                            : 544 pixels
    Height                           : 372 pixels
    Display aspect ratio             : 16:9
    Frame rate                       : 29.970 fps
    Resolution                       : 8 bits
    Colorimetry                      : 4:2:0
    Scan type                        : Progressive
    Bits/(Pixel*Frame)               : 0.048
    Stream size                      : 41.9 MiB (80%)
    Audio
    Format                           : AAC
    Format/Info                      : Advanced Audio Codec
    Format version                   : Version 4
    Format profile                   : LC
    Format settings, SBR             : Yes
    Format settings, PS              : No
    Duration                         : 20mn 18s
    Bit rate                         : 64.3 Kbps
    Channel(s)                       : 2 channels
    Channel positions                : L R
    Sampling rate                    : 44.1 KHz
    Resolution                       : 16 bits
    Stream size                      : 9.35 MiB (18%)
    Apr 2005
    Rio Grande - Porto Alegre - RS - Brasil
    The WD TV Mini plays RM and RMVB files.
  11. Banned
    Freedonia
    The WD and WD Live players are great for playback, but as others have pointed out, FLV and RM are not supported. Few other devices support them, so no big deal. I can't promise you that 100% of what you download will work in the player, but I can tell you that I have never yet downloaded a file my older WD HDTV player won't play. Do note that HD audio formats such as DTS-HD and Dolby Lossless are NOT supported.
  12. Member yoda313's Avatar
    Jun 2004
    The Animus
    Plus the obvious caveat that you need a dts receiver for playback of sd dts soundtracks.
  13. If you want something that can play everything use your computer connected to your TV.
    Jan 2008
    It's easier to buy one of these devices than a Video card with HDMI. Then you gotta go to the PC to select what you want to play.
  15. Video Restorer lordsmurf's Avatar
    For computers that will play anything, look at the HP Slimline systems:
    http://www.amazon.com/gp/redirect.html?ie=UTF8&location=http%3A%2F%2Fwww.amazon.com%2F...reative=390957
    I have one of these, works great.
    Comes with a remote, Windows Vista x64, HDMI out.
  16. Crazy14music . your file is AVC in an FLV overcoat.
    Video
    Format : AVC
    Strangely the WDHDTV mini does playback rmvb files. The Viewsonic 74 is very similar (specs) to the wd but also plays back BBC IPLAYER, if you in UK. Netflix elsewhere
    Feb 2001
    europe
    Nothing plays everything, but this plays quite a bit. FLV is still a bit spotty, it doesn't recognize a lot of formats. But it does play some. Though if you want to you can often extract the sound and video from the FLV and mux them into an MKV container and that'll play fine.
  18. I know people have said they play mp4 & x264, h264 but I encode in x264 AVC high profile. Any problems with that encode on the WD TV Live?
    Thanks in advance.
    Danneauxs
  19. Originally Posted by Danneauxsvh View Post
    What encoder? There are some problems with some h.264 encoders (on the Mac I think) and the MP4 container. For example, files from Revision3's HdNation and GeekBeatTV don't play smoothly. Everything I've made with x264 under Windows works fine. It even plays 1920x1080p60 h.264 made with x264.
  20. I'm using Staxrip latest version to encode. BUT more precicely it's the AVC "High" setting that I'm concerned with at this particular time. For instance my ARchos 504 plays "baseline" x264 encodes fine, but will not play "main" or "high".
    below is info pulled from mediainfo on a short encode the avc high@L3.1 & CABAC might be the problem parts? Maybe?
    I generally use HIGH profile over Baseline because there is a noticable difference in certain of my encodes; particularly the tv episode encodes which are very low MB and look better on High profile.
    Thanks in advace.
    General
    Complete name : E:\MainMovie\GILBERT_GOTTFRIED_DIRTY_JOKES\VIDEO_T S\test.mp4
    Format : MPEG-4
    Format profile : Base Media
    Codec ID : isom
    File size : 4.13 MiB
    Duration : 50s 48ms
    Overall bit rate : 692 Kbps
    Encoded date : UTC 2010-11-22 09:27:52
    Tagged date : UTC 2010-11-22 09:27:52
    Video
    Format : AVC
    Format profile : High@L3.1 & CABAC setting
    Format settings, CABAC : Yes
    Format settings, ReFrames : 8 frames
    Codec ID : avc1
    Duration : 49s 949ms
    Bit rate mode : Variable
    Bit rate : 649 Kbps
    Maximum bit rate : 982 Kbps
    Width : 688 pixels
    Height : 432 pixels
    Display aspect ratio : 1.447
    Original display aspect ratio : 1.448
    Frame rate mode : Constant
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Bits/(Pixel*Frame) : 0.073
    Stream size : 3.86 MiB (94%)
    Title : Video
    Writing library : x264 core 105 r1724 b02df7b
    Encoding settings : cabac=1 / ref=8 / deblock=1:-1:-1 / analyse=0x3:0x133 / me=umh / subme=9 / psy=1 / psy_rd=1.00:0.15 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-3 / threads=4 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=60 / rc=crf / mbtree=1 / crf=22.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
    Audio
    Format : AAC
    Format profile : LC
    Codec ID : 40
    Duration : 50s 48ms
    Bit rate : 40.1 Kbps
    Maximum bit rate : 43.5 Kbps
    Sampling rate : 48.0 KHz
    Compression mode : Lossy
    Stream size : 245 KiB (6%)
    Language : English
  21. I don't anticipate any problems with that video. Upload a sample and I'll try it out.
  22. Cool, sorry didn't respond earlier the e-mail notice about a reply got filtered.
    This sample isn't the one I posted about but it's encoded the same. The biggest problem devices seem to have is with the HIGH vs BASELINE setting. This might be mute once my Archos 101 arrives; I'll be encoding to suit that if I keep it.
    Thanks Again.
    Danneauxs
  23. Originally Posted by Danneauxsvh View Post
    The sample played fine on my WDTV Live. Fast forward and reverse worked too.
  24. Thanks much Jagabo this basically makes my decision for me.
    Again thanks
    Danneauxs
