Need help with importing h264 files into virtual dub.
I have tried downloading h264 vfw files as it does show in virtualdubd but still get an error message when trying to install . I i have also tried changing the setting in ffdshow but still no luck. enven tried super encoder but errors still. I have Km player . dvix pro , vcl , and k lites installed so there really cant be not having a the right codec. I aslo tried using the virtual dub mob but when i try to open the moded version it never opens...........
if any one has a solution or is willing to even upload a working virtual dub files iwould appreaciate it ( been sitting here since 5 am serching trying to get this thing to work so ill take anythinig as long as it works)...................
I have no exact idea what you are trying to do.
Did you try the x264 VfW?
This work very nice here in VirtualDub.
You can find it and more info here:
Doom9: DeathTheSheep United - x264 Guide and VfW Builds -
There's a plugin for this. Easy.
I've attached it.
Extract it to the /plugins32 folder in the main VirtualDub program folder.
And then here's the full VirtualDub install that I use (preloaded with necessarily filters/plugins we use)
http://www.digitalFAQ.com/forum/showthread.php/virtualdub-filters-pre-1727.html
Side note: NEVER INSTALL A CODEC PACK. That may give you other problems now.
Read my comments in this thread: https://forum.videohelp.com/threads/320568-Want-to-use-K-Lite-DON-T-DO-IT!
H264 conversion problem Virtualdub
By Shadowofthedarkgod in forum Video ConversionReplies: 11Last Post: 8th Nov 2015, 14:42 -
Virtualdub opening H264 encoded file
By tvbear in forum EditingReplies: 0Last Post: 26th Dec 2011, 07:22 -
Cannot open H264 video using VirtualDub
By kinlunyu in forum Video ConversionReplies: 12Last Post: 21st Aug 2011, 15:28 -
VirtualDub: can no longer play H264
By terrypin in forum Newbie / General discussionsReplies: 5Last Post: 29th May 2011, 14:15 -
virtualdub and h264-no error
By uglijimus in forum Video ConversionReplies: 14Last Post: 13th Jan 2011, 22:04
