I installed AviDemux in both Window XP and Ubuntu 10.04 attepmting to open, edit and convert MP4 clips captured with a Flip video camera. In windows as soon as I browse to the folder with the Mp4 files using Avidemux "File Open" the AviDemux closed without error, just dissappeared off the screen. This happens over and over with all MP4 videos which open fine in Flip and Nero. If in Windows I right click and use "Open With" and choose Avidemux I do get a warning "H.264 detected, B Frames are used as a reference that can lead to a crash or shuttering - Can use another mode but may lead to frame shuttering" than if fails to open the file. Does AviDemux support MP4?
In Ubuntu I can open the files and edit and when I save a MPEG but no other video editing program will open them as they are unrecognised format. AviDemux creates files with a format that nothing will recognise.
I Am at a loss to understand why this software does notsupport MP4 in eithewr Windows or Linux and appears useless.
Can you suggest any steps to troubleshoot this problem.
I noticed on CNET reviews many other prople reported the issue of files complied that could not be opened in any other program so i am not the 1st to encounter this problem.
Suggest you post the log from MediaInfo of one of the files so that all the details of the file are available. For waht it's worth I can open my MP4 files in AviDemux without issue - I get a warning that H264 is detected and then opens ok. First a green screen withing the preview monitor and then scrolls along ok - although the aspect ratio is wrong. I haven't needed to use AviDemux on any of my MP4's so haven't investigated it beyond opening and scrolling..
SONY 75" Full array 200Hz LED TV, Yamaha A1070 amp, Zidoo UHD3000, BeyonWiz PVR V2 (Enigma2 clone), Chromecast, Windows 11 Professional, QNAP NAS TS851 -
Hi
I notices in Windows that i get different results if I go to the file and use Open With, then i can choose AviDemux and get the warning about B Frames and open in Safe Mode and save OK to AVI format. If I choose MPEG format i get a file that no program recognises. I use Video ReDo to trim files and it reads TS streams and MPG formats and gives my the best cutting interface but with AVI format I have to use Movie Maker or other less functional programs. Nero reads MP$ OK bbut can only save to VOB as when I chose Export it immediately crashes.
The point is AviDemux seems to be very flaky. For example in Ubuntu it can open MP4 and save a MPEG file and it cannot itself open its own creation. Essentially I want to convert my MP4 to MPg just to use a better cut and join interface and resave as a single MPG stream.
I can't be the 1st to have encountered this problem.
Why give a file format as an option if it canot open it own files?
What does it create when you chose MPEG and what is the IDX files it also creates about? -
Post a mediaInfo log so we can see what's going on - you seem to be asking several questions all mixed up in the one post - maybe if you restrict your question to one item at a time would be helpful and more clear.
In backwards order - idx is a subtitle format
MP4 and compressed avi's, xvid's etc are not the ideal format for editing due to the compression used to produce small files.
For frame accurate editing you really need to have uncompressed avi's or MPEG2.
Re MPEG TS files (probably from DVB TV sources) should really be demuxed first in ProjectX to eliminate transmission errors and give you a clean audio and video and subtitle track - see my signature for a Wiki on setting up ProjectX for Australian conditions.
One cannot really complain about free programs like Avidemux if they don't do what you perceive they should do - read the authors page and communicate directly with him on your suggestions, critique of his program.
Do some study on file formats and their advantages and disadvantages. The ideal video editing format is where there is an analog to 35mm film ie the equivalent of actual frames - this is certainly not present in MP4 or indeed MPEG2 (but in the case of MPEG2 there are now frame accurate editors like Womble, Vegas Final cut Pro etc)SONY 75" Full array 200Hz LED TV, Yamaha A1070 amp, Zidoo UHD3000, BeyonWiz PVR V2 (Enigma2 clone), Chromecast, Windows 11 Professional, QNAP NAS TS851 -
Hi Netmask56
Thank you for your good advice about accurate editing. The files I need to trim and join were created on the Flip camera saved as MP4 so there is nothing i can do about the format. if it was captured in TS of MPG VideoReDo would trim and join in a jiffy.
You say post MediaInfo like I should automatically know what this means.
I downloaded MediaInfo and installed it and it showed that my System supported MP4 however suggested i get Quicktime update (7.66.71.0) which I also installed. This seemed to allow AviDemux to open MP4 files without error which is a major step forward in Windows.
Now if I try to trim a MP3 file and save as MPEG video and still end up with a file that I cannot open in any application that normally reads MPEG files just like in Ubuntu. AviDemux does not give the file any extension so I add .MPG which makes no difference.
What format do you recommend I save to and why does the MPEG files that AviDemux appear corrupt and completely useless?
Using Media Info if I open the MPG file I created it tells me nothing about the file except its path and size. You have not explained how I creat or post a log? A log of what? -
The reference to MediaInfo was to get you to get the program if you didn't already have it and then run it and post the log file of one of your files - then the good folk here would be in a better position to provide some help. It's a pretty basic request for any problems with video and audio files, another program that is similar is GSpot. Now that the you have revealed the source of the files then there is a possibly solution by using MP4Cam2AVI and converting to uncompressed avi. You can load this converted file into VirtualDub to do the trimming and joining etc
A typical MediaInfo log (from my Sanyo MP4 camera)
Code:General Complete name : N:\SoftwareBackUps\SanyoCamera\HD1080iFiles\SANY0016.MP4 Format : MPEG-4 Format profile : Base Media / Version 2 Codec ID : mp42 File size : 23.7 MiB Duration : 16s 449ms Overall bit rate : 12.1 Mbps Movie name/More : SANYO DIGITAL CAMERA HD1000 Encoded date : UTC 2008-05-04 17:53:17 Tagged date : UTC 2008-05-04 17:53:17 Origin : Digital Camera Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : Main@L4.0 Format settings, CABAC : No Format settings, ReFrames : 2 frames Codec ID : avc1 Codec ID/Info : Advanced Video Coding Duration : 16s 449ms Bit rate mode : Variable Bit rate : 11.8 Mbps Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 59.940 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.095 Stream size : 23.2 MiB (98%) Language : English Encoded date : UTC 2008-05-04 17:53:17 Tagged date : UTC 2008-05-04 17:53:17 Audio ID : 2 Format : AAC Format/Info : Advanced Audio Codec Format version : Version 4 Format profile : LC Format settings, SBR : No Codec ID : 40 Duration : 16s 448ms Bit rate mode : Variable Bit rate : 128 Kbps Maximum bit rate : 192 Kbps Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 48.0 KHz Stream size : 256 KiB (1%) Language : English Encoded date : UTC 2008-05-04 17:53:17 Tagged date : UTC 2008-05-04 17:53:17
How to open .MP4 files in virtualdub? (i want to sharpen mp4
By fuc847 in forum Video ConversionReplies: 27Last Post: 22nd Apr 2015, 08:06 -
Can't Open a VERY Large MP4 File?
By ShadowfaxSTF in forum Video ConversionReplies: 3Last Post: 27th Jun 2011, 11:50 -
Video nightmare, Cannot open .mp4, please help.
By airrore in forum Video ConversionReplies: 16Last Post: 13th Apr 2011, 21:22 -
how 2 open mp4 & mkv video files in vdub
By naveenkrish in forum EditingReplies: 2Last Post: 19th Jun 2010, 22:14 -
Can't open mp4's in Sony Vegas
By ClownInBrown in forum Newbie / General discussionsReplies: 7Last Post: 8th Jul 2009, 13:43
