What would be the best way to utilize the available tools here in this forum in order to:
1) Yield best quality?
2) Easier/less complex process with at least very good quality?
3) Easy, no brainer solution which would result in good quality?
If successfull, I may just buy a used one.
I need to know how to do this so I can match/downconvert any A1 footage to "match" my GL-2's.
Thanks in advance.
What do you guys think about Xilisoft HD Converter 6 and the like?
My vote is for AviSynth and HCEnc (both free) for transporting to DVD.
in a nutshell:
1) Edit your video (trims/color correction/etc) and output to high quality codec (HDV?)
2) Make AviSynth script to deinterlace/resize/interlace/etc.
3) Open script with HCEnc and encode to a pristine mpg file
the scripts are intimidating but there is plenty of help here..I'll show you the one I used for converting my 1080/60i avchd stuff to 480/30p -
Gunslinger: My target/initial format will be plain old .avi or maybe MPEG-2 since TS files are so huge to begin with.
I probably could just rename the file extension I guess in the latter case.
Ultimately, the end result will be put on a dvd.
How to fit in on there will be another story/ future thread.
Please, what would please explain in some detail your top solutions for this mission factoring in I'm a nubie to down-conversion?
GreyMalkin: I know nothing about Avisynth nor scripts so I'll leave that to the programmers and experts!
Thanks to you both. -
export from the a1 as DVavi. the camera's hardware conversion can't be beat by any software.
Date/Time Stamp for HDV Footage
By lasereyes in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 26Last Post: 18th Mar 2019, 02:25 -
CS 5.5.2 fails to export HDV footage to tape/perplexed
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 6Last Post: 19th Apr 2012, 21:41 -
Cannot capture HDV with Canon HV30
By ChrisU in forum Capturing and VCRReplies: 49Last Post: 4th Mar 2012, 21:56 -
Producing DVDs from HDV footage
By lasereyes in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 1st Mar 2009, 17:25 -
Inclusion of DV footage into HDV format project
By adanchev in forum Newbie / General discussionsReplies: 1Last Post: 2nd Jun 2008, 01:34
