I have a few home movies that were recorded with my compact digital camera. I need to cut a few minutes off the beginning and end. I know I can use something DVD Shrink. Is there anything else that can do this? Possibly better than DVD Shrink.
Compact digital cameras do not produce anything that DVDShrink can work with. Download AviDemux, cut only on key frames, set video and audio to COPY and output your new shortened video somewhere where you can find it easily. Don't forget to add the file type(Avi, mpeg, etc etc) to the end of your output file name....make sure it matches the file you are editing.
DVD Shrink wont work with AVI format? I have done it before with VOB so I just figured it would work.
It's called DVDShrink, not AVI shrink
LOL!
That's because VOB is the standard dvd file format.
Is it actually "avi" your camera produces ?
After all, avi is just another container.
https://www.videohelp.com/glossary?A#AVI
open it in Gspot and it should tell you exactly what you have.
But yeah, AviDemux is a good suggestion if you have the correct file/s, i use it quite often.
how to author a DVD from the beginning to the end
By michcio in forum User guidesReplies: 3Last Post: 13th Apr 2012, 18:43 -
How do I clean up (trim) beginning and end of DVD?
By perceptionist in forum EditingReplies: 6Last Post: 28th Mar 2010, 01:29 -
automatically cut out beginning & end of a video
By ari.kulmala in forum EditingReplies: 1Last Post: 25th Aug 2009, 16:44 -
Boilsoft Video Joiner - Cutting Off Beginning of Videos?
By imrealdumb in forum EditingReplies: 3Last Post: 14th Jun 2009, 22:24 -
Adobe Premiere Elements is cutting off the end of video when exporting
By robvs in forum EditingReplies: 0Last Post: 19th May 2009, 18:47
