    Jul 2008
    Singapore
    VOB2mpg v2.3 hit error msg unhandled exception - length cannot be less than zero
    on win7pro 64bit machine.
    Thks.
    Jul 2008
    Singapore
    Printscreen of the error
    USA
    CrissyBoy usually checks in every few days, standby. But I would check to see where the program is looking for files. It may be using a bad data address.
  4. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    2006/v2.3 - may I suggest you look at the latest version? At least with v3 there will be more diagnostics should the issue remain.
