Hi everyone,
I am recording European HDTV channels with a satellite receiver as TS files (transport streams). I want to author BD-Rs or AVCHD DVDs with menus from them.
I'm currently using DVR-Studio HD 2 from Haenlein Software for it.
My problem is that some HDTV channels air their programs with MPEG-2 audio tracks that are not Blu-ray compliant, so I have to demux the audio and convert it to AC3. This in itself is not a problem, but because DVR-Studio HD 2 only accepts TS and M2TS files as input, I have to remux the converted audio back into the original TS files.
I succesfully did this using the software TsMuxer. Only that 720p50 video files (some German HDTV channels broadcast in that format) heavily stutter on my Sony BDP-S350, if they have been touched by TsMuxer.
Does anyone know a different multiplexer I could use for either muxing an AC3 audio track back into an existing TS file or for creating a new TS file?
I already tried Elecard XMuxer Pro, but it also results in stuttering video on the Sony Blu-ray player. Interestingly the stutter problem doesn't exist on the PS3 of a friend.
you can try multiavchd
another possibility is your stream has problems; ps3 is more robust than most blu-ray players and can play some non compliant streams -
I've already tried multiAVCHD, but it internally uses TsMuxer.
If I create a BD-R from the untouched 720p50 TS file from my satellite receiver, the Sony BDP-S350 plays it without problems. It's only when I remux it with either TsMuxer or XMuxer Pro that the video stutters. So some kind of problem seems to be introduced, but I don't know what exactly.
I think I have to find a different program for remuxing it into a TS or M2TS file. So far I couldn't find one. Are there others I could use? -
the author states multiavchd uses a different muxer than tsmuxer , I think a long time ago it was based on tsmuxer
no other free options that I know of , you could use DVDA, Encore CS4/5 , Scenarist, DoStudio Authoring Studio, Blu-Print
maybe it's the ac3 stream? what did you use to convert?
x264 GUI specifically for blu-ray compliant elementary streams
By turk690 in forum Authoring (Blu-ray)Replies: 3Last Post: 25th Apr 2012, 19:20 -
3 movies, 6 elementary streams, 1 DVD
By Pholder in forum Authoring (DVD)Replies: 1Last Post: 5th Aug 2010, 08:51 -
demux a .mp4 to elementary streams
By halsboss in forum Video ConversionReplies: 4Last Post: 28th Nov 2009, 16:38 -
How do you join elementary streams?
By rayden54 in forum EditingReplies: 0Last Post: 5th Jan 2008, 20:43 -
From DVD VOBs to proper elementary streams
By gabier in forum Video ConversionReplies: 9Last Post: 28th Nov 2007, 21:48
