i have an mkv files and when i extract using MKVExtract GUI ; i found file with xxxx.H264 extention and looks like my program does not recognize it ...
and my question ... is there any programs to encode or compress these xxxx.H264 files to .H264 again with feature which i can decide the size of the file, cause i need to compress those file and merge again using mkvmerge.
my files originally around 500 mb for 25 minutes and thats a problems for 100++ episode for just an 1 title ...
im really desperate to compress to around 250 mb or 300 mb
anyone can help me ???
Don't extract it, use the original format in .mkv container. Most programs have problems opening raw avc files
i'm assuming you don't want to hardsub
use mkvtoolnix to remove all other streams you don't want (uncheckmark them) => mux a new mkv
you can add back soft subs after it's re-encoded with mkvtoolnix
You can use for example: ripbot264, handbrake, staxrip , megui, xvid4psp , many others etc... to compress -
i think its works ....
mux a new mkv => Extract sound, subtitles and font using Mkvextract => encode the mux mkv => join all files with mkvtoolnix
i post the result tomorrow (its not tomorrow again at my country, its nearly morning here 4 o'clock ...)
i gotta sleep ...
you don't need mkvextract , use mkvtoolnix and uncheckmark the other streams in 1 step
Well if i dont mkvextract to extract the subs and font and just using mkvtoolnix, the subs wont be shown. either with mkvextract for extract font, subs and than mux again with mkvtoolnix .... the subs are shown exactly like the original files ...
VirtualDub Video Compression h264 encoder Not Shown
By darkw1zard in forum EditingReplies: 2Last Post: 18th Oct 2011, 14:28 -
h264 (MP4) to XviD (AVI) Conversion Trouble
By m93 in forum Video ConversionReplies: 5Last Post: 12th Dec 2008, 10:21 -
How do I convert videos to RMVB with H264 video compression?
By creamsoda in forum Video ConversionReplies: 3Last Post: 19th Apr 2008, 18:59 -
H264: Are there other h264 (AVCHD/VC-1) encoding command-line/CLI tools ??
By vhelp in forum Newbie / General discussionsReplies: 12Last Post: 16th Feb 2008, 01:20 -
H264 Compression Sorenson Squeeze... HELP!
By DWTV in forum Video ConversionReplies: 8Last Post: 27th Jul 2007, 15:36
