I am trying to figure out what i should use to convert/burn video files to DVD on my macbook, and figured I would start by asking you guys what you use.
so what do you use to burn dvds on your mac?
Thread moved to mac forum.
For DVD, iPad, HD, connected TV, … iMovie & FCPX? MovieConverter-Studio 3 (01/24/2015) - Handle your camcorder's videos? even in 60p or 60i? do a slow-motion? MovieCam.
But Herve, he was asking for "our" preferences....which in itself is a loaded question,
that can have varying answers.
There is simply no "best" answer in this case...it comes down simply to what
you prefer to do: (A) get the data quickly to DVD and watch it in the living room,
which often involves less headache as the software does the converting "thinking" for you,
or (B) take some time with the data to make a fancy showpiece DVD that
is customized somewhat ( or a lot), but requires you to have the data just right, or at
the very least, know what to do to get the data right beforehand.
Apps that can do (A) include:
ffmpegx
visualhub
MpegStreamclip ( with QT Mpeg-2 addon)
Apps that can do (B) include:
iDVD
LiquidCD
DVD Studio Pro
Apps that do a bit of both :
Toast Titanium
If your new to this, My suggestion would be an app like Visualhub or ffmpegx, or iDVD
(provided the video data files were imported first into iMovie)
which you just drop the data in, tell it what you want ( A DVD Video_TS folder
ready to burn to DVD) and let it go.
Once you get an idea on different formats of video data ( .avi, .wmv, .flv, dv stream,
.mov) and their complexities, ( when and when not to re-encode, etc.)
then I would say move to something a little harder with more user input, like Toast or
DVD Studio Pro....
hope that helps ( more somewhat)....
then"Everyone has to learn, so that they can one day teach."
When I'm not here, Where can I be found?
Urban Mac User -
Assuming the files aren't in some bizarre format, iDVD and Toast are good choices. FFmpegX can author, if you wish, but it introduces some complexity with which you may not wish to deal.
Although this may fall outside your comfort zone, why not forget about authoring anything and, if it plays on your Mac, plug it into your TV (or use a WD TV Media Player) and simply play what you have? Why bother with discs at all (except maybe to burn the files for backup, if you wish, to a Mac/PC compatible disc). -
For conversion I use Apple's Compressor, and for burning I use DVD Studio Pro. However, depending on the format the videos are in to start with, you can drag them right into iDVD, which will do both the conversion and burning for you. If the video file is one that iDVD doesn't like, get a copy of MPEGStreamClip, which is a free program.
Mac....which program(s) would be best?
By JonnyPhoenyx in forum MacReplies: 6Last Post: 3rd Nov 2010, 18:34 -
Epson Print CD Program - going from MAC to PC
By Andii in forum MediaReplies: 7Last Post: 14th Aug 2010, 17:26 -
im new to mac... is there a mac program that does what tmpgenc dvd author 4
By ochsfamily in forum MacReplies: 0Last Post: 12th Dec 2009, 22:13 -
Reliable ripping program for mac?
By mopar339 in forum MacReplies: 2Last Post: 13th Feb 2008, 23:21 -
Is there a program like Super for Mac OS X?
By 42wolves in forum MacReplies: 4Last Post: 27th Nov 2007, 09:27
