Looking for a program BDShrink (like DVDShrink) for BD to BD5 (DVD-R) Conversion.
How to convert Blue Ray Disc to DVD (DVD-R, 4.7GB) with preservation main menu, audio and subtitle setup menu, removing all extras, so that it can be played in any stand alone DVD Player with main menu, audio and subtitle selection?
Closest thing would be to rip with AnyDVDHD or DVDFabPassKey running in the background, and extract the main movie *with menu* using ClownBD BDCopier. That will remove all extras. Then re-encode to BD 5 or whatever with BDRB, full disc. But I don't think any setup menus will work, just the main menu. Try it, maybe I'm wrong about the setup menus.
Mind you, such a disc will *NOT* play on a DVD player, but will play on a Blu-Ray player that can play AVCHDs.Last edited by fritzi93; 30th Jun 2010 at 18:09.
Pull! Bang! Darn!
Playing AVCHD "BD5" discs incl menus from MultiAVCHD on PC
By R.A.J. in forum Software PlayingReplies: 1Last Post: 5th Apr 2011, 11:44 -
Is there any recent/uptodate list for bd players that play bd5 bd9 bdr/re?
By fjmr in forum DVD & Blu-ray PlayersReplies: 1Last Post: 18th Jul 2010, 08:36 -
If there is a BDJO file, can't burn to BD5/9
By Nitrousbird in forum Blu-ray RippingReplies: 2Last Post: 27th Mar 2010, 18:54 -
BD5 problems with converted files
By briansxx1 in forum Blu-ray RippingReplies: 1Last Post: 14th May 2009, 09:20 -
AVCHD vs BD5/BD9?
By Randm in forum Newbie / General discussionsReplies: 9Last Post: 10th May 2009, 08:41
