i have a .mov file i'm trying to convert to DVD in visual hub.
the problem is that the orginal file seems to be a 4:3 image encoded as 16:9 anamophic (pillar boxed right and left).
visual hub will only make me 4:3 DVD resulting in the image being squashed.
according to the visual hub users guide, there should be options to force standard/anamorphic, full resolution or dual layer under the DVD advanced settings, but when i open DVD advanced settings, the pop up menu gives me a choice to force quicktime decoding, ffmpeg decoding or VLC decoding. (completely different !?!)
am i missing something ? or can someone please suggest a workaround ?
thanks.
*sigh* Another issue - "force mono" missing in AutoGK.
By teapot in forum Newbie / General discussionsReplies: 7Last Post: 15th Apr 2013, 19:32 -
Creating "force-play" DVD chapters using a Mac?
By Cyrax9 in forum MacReplies: 10Last Post: 19th Jan 2010, 06:45 -
AutoGK question: Can I "Force IVTC" on "Hard-encoded NTSC&am
By BozQ in forum DVD RippingReplies: 11Last Post: 12th Jun 2009, 13:46 -
Need help converting DVD video using MeGUI's "clever anamorphic"
By mjensen in forum DVD RippingReplies: 0Last Post: 5th May 2008, 09:41 -
Decrypter "Brute Force" mode can damage the writer, or produce ba
By Bruxo in forum DVD & Blu-ray WritersReplies: 5Last Post: 2nd Dec 2007, 15:26
