I am using PowerDirector 8 Ultra to produce HD video from a Sony HDR-XR550VE camcorder. The editing software can output h.264 format to a file. Am I correct in thinking that I could if required archive the files created to a DVD without subsequent loss in image quality. I know I can't 'play' the saved footage (at top quality) but if these files were loaded back onto a HDD one could either play them on a HDTV using say a Western Digital TV HD 1080p Media Player (via USB) or else write content to a Blu-Ray disc.
You can play them from DVD5/9 media, from a blu-ray player or ps3, if they are authored correctly. A free tool to do this is multiavchd
You lose some quality by exporting from power director (generation loss), because at least some parts are re-encoded.
If you really meant "archive" as in the original format & quality, you could take your original clips and use multiavchd
If you make a plain old data disc (not authored) , it won't play on a blu-ray player or ps3 , but you could recover the data on a PC
Decent econmical way for converting 8mm (analog) video to H.264 files?
By salils in forum Capturing and VCRReplies: 5Last Post: 26th Dec 2011, 16:17 -
Empty audio files when converting MPEG2 with h.264 mencoder or h.264 x264
By doctormelodious in forum ffmpegX general discussionReplies: 3Last Post: 4th Jul 2010, 09:12 -
file format for storing video files (wmv or h.264)
By the_shyguy in forum Video ConversionReplies: 24Last Post: 10th May 2010, 02:21 -
Help with keeping quality for archiving my video files. Interlace source
By drewzor in forum Video ConversionReplies: 11Last Post: 8th Mar 2010, 19:32 -
Slowing down PAL H.264/X.264 files
By ID3_Freak in forum Software PlayingReplies: 6Last Post: 8th Apr 2008, 18:39
