I was trying to switch my karaoke DVD (and VOB files) audio channels back and forth, so that I can have collections of karaoke in which all the audio channel positions are in a same order (could be the vocal channel first and the instrument channel second or vice versa), so does anyone know how to do this?
Results 1 to 10 of 10
You'll probably have to swap the audio in an audio editor. And then re-author.
Thanks lordsmurf, but will the quality be exactly the same? And what programs should I use?
Can I clarify - are you talking about the Channel order - right, left, centre etc, or the Stream order - audio track 1, audio track 2 etc ?
One requires changes in an audio editor, as previously indicated, and the other is an authoring issue which may be far simpler to resolve.Read my blog here.
Sorry again for not being clear guns1inger, I think it's the stream order, like moving the "French" to the top and let the "English" be the second option in the "language section" in a DVD movie, thanks!
Thanks, I will try that out, but is there any more good soft that you recommend?
If these VOBs come from the same DVD then using IFOEdit is pretty easy. There is a simple Create IFO button. Just click this button, and open the first VOB in the set. If things are more complex than that then you may have to use DVD Styler or GUIForDVDAuthor, import the VOBs, and author a new disc.
Read my blog here.
Use Ifoedit and associate ifo files with Ifoedit . Open the DVD in explorer and double click the ifo file you want to change. In the upper window double click VTS _PGCITI and any PGC's will drop down. Click one of the PGC's. Now look in the lower window and you will see all the streams in that PGC,look and you see the audio streams listed. Under the Value column you will see a numeric value for each audio stream. Double click each audio stream,a box will open to allow you to change the value. Transpose the value numbers and you will have changed the order of the audio streams.
Premiere: Duplicate left audio channel to the right channel?
By ash_melb in forum EditingReplies: 7Last Post: 21st Oct 2015, 12:32 -
-acodec copy to 6 channel audio results in 2 channel?
By ninethirty in forum Video ConversionReplies: 1Last Post: 11th Feb 2011, 12:54 -
DVD with mono audio channel...can i convert to two channel
By maass in forum Newbie / General discussionsReplies: 3Last Post: 1st May 2009, 22:46 -
Convert single channel to double channel audio ...
By tariq_niazi in forum AudioReplies: 3Last Post: 15th Nov 2007, 17:47 -
How to switch downloaded avi/rmvb audio channel?
By Dewprismzz in forum Newbie / General discussionsReplies: 2Last Post: 5th Nov 2007, 15:55
