Use ConvertXtoDvD to convert 6 Episodes of a series, 45 mins each.
Unfortunately when I listed out the Episodes in the Menu, I made a Mistake:
Episode 1
Episode 2
Episode 3
Episode 4
Episode 5
Episode 16
Instead of Episode 6, I mistyped and typed Episode 16
any chance I can Redo the Video TS File, and NOT have to Redo and start all over again. I know is a long shot.
Thanx.
	You would have to redo the menu. Something like DVD Remake can probably do this. You might be able to use menuedit. Otherwise it is a manual process and it would be quicker to just re-author the disc. Read my blog here.
	Thanks for pointing me in that direction, unfortunately, I do NOT know how to use DVD Remake, below is a screenshot, How can I change the Menu From Episode 16 To Episode 6.with DVD Remake?
 Uploaded with ImageShack.usLast edited by niteghost; 28th Jun 2010 at 23:44.
	Mod can close this thread, I have Redo it over again with ConvertX, since no one responded how to use DVD Remake to do it. Thanks ......sigh!!!
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
