I've used ulead dvd movie factory 4 to cap with this card for years. I recently installed a new copy of XP, now ulead is stating "failed to connect to driver". I've installed the driver and tried re-installing ulead, but no luck.
Suggestions?
Results 1 to 15 of 15
I'm very grateful. But ulead still couldn't connect to the card.
Ulead is asking me the field order upper or lower first?Last edited by pinetop; 28th Jun 2010 at 16:25.
Upper field first for PAL Video or lower first for NTSC Video
Thanks I understand the field order question.
Heres the ulead error:"Failed to connect to driver: Hauppauge WinTV PVR2 USB2 Encoder"
Any other suggestions? -
Did you update to DirectX 9.0c and install Windows XP Service Pack 3 and go to Windows Update and get all update?.
I have XP sp3 and Direct Xsdk which I believe has c in it. I believe hauppauge provides direct xb with the card's software cd.
I noticed since this new windows install my other card an ATI tv wonder 650 doesn't work with Catalyst and Power Cinema. Both programs state that they can't access the live tv function. Both programs worked fine before I re-installed XP.
Should I go into regedit and change something? -
something wrong with XP install if ATI tv wonder 650 doesn't work I don't what else to tell you
That is only option after that done install XP SP3 and DirectX first before any thing else
Then install your Motherboard chipset drivers then Video and Sound card drivers -
I don't have the drivers to the motherboard, video and sound cards. How can I tell what drivers I need?
And thanks for helping. -
One way is you need look on the Motherbaord for the model number there usely by a ISA, PCI or PCIe slots and some times at back of the baord or buttom side of the board
Other ways are by Bios Number
Just google by looking for "model number on the motherboard" or "how to identifying a motherboard" and for Bios it "how to find bios number" or "check bios info"
Useful tools that may help by check out http://majorgeeks.com/downloads9.html
EVEREST Free Edition - Successor to AIDA32
ASTRA32 - Advanced System Information Tool
HWiNFO32
CPUID = CPU-Z and PC Wizard
The above tools will help you gathers information on all devices in your system. -
If I'd known I was going to live this long, I'd have taken better care of myself.
Always remember, The Device Manager is your friend.
But seriously, Once you get everything working good, use cloning software to create a backup of the freshly installed system so you can get it back easily. my 2 favorites.
drive snapshot - trial version works great, use BartPE or similar to restore.
http://www.drivesnapshot.de/en/down.htm
easus backup- free simple version on a boot disk.
http://www.easeus.com/disk-copy/download.htm -
Thanks for the help! I am so grateful. My computer is a Dell, I was able to download the bios and drivers from their website. Both the hauppauge and ati cards are working. My world is normal again.
Hauppauge HD-PVR 1212 recording problem at CBR
By rds11 in forum Capturing and VCRReplies: 9Last Post: 10th Dec 2011, 16:12 -
By mail2tom in forum Capturing and VCRReplies: 5Last Post: 27th Aug 2011, 16:34 -
What software for capturing Hi-8 with Hauppauge WinTV 250 PVR USB2?
By boscabru in forum Capturing and VCRReplies: 10Last Post: 5th Mar 2008, 02:19 -
Hauppauge WinTV PVR USB2 locks up in Vista Premium after 20 min
By SpaceCowboy9 in forum Capturing and VCRReplies: 5Last Post: 10th Aug 2007, 07:19 -
Dilema: Hauppauge 99016 or WINTV-PVR-USB2?
By WetLight in forum Capturing and VCRReplies: 0Last Post: 11th Jun 2007, 04:42
