Hi,
i'm a newbie on Mac which a bought one year ago. I don't have problems handling with basic stuff but discovering the Mac OS X platform and video formats, codecs and featured app i'm losin' it. More a discover i get more questions, seems the Windows are more compact to the video environment.
ok, my problem is handling with MKV (1280x720, x264, AC3 5.1 DD) files with additional subtitle in .srt. Is any way to add subtitles (.srt) to video without encoding the audio and video chanells on MAC? How can i burn DVDR on Mac with subtitles and save the qulaity of Video and Audio chanells?
I've been trying with AddMovie, ffmpegx, Submerge, etc but no luck.
Pls any suggestion?
Results 1 to 12 of 12
You can try to extract the video and audio from the .mkv using MKVToolsnix and then taking those assets,
along with the sub file and place them in either an .avi or .mov container within Quicktime Pro,
but all you doing at that point is switching form one container format (.mkv) to another (.avi or .mov),
which is fine for computer watching.
x264, you will either have to (a) leave it as is, and simply watch it as a computer file rather than a DVD,
or (b) use a high end transcoder like Compressor ( part of FCS Studio) or Sorenson Squeeze to encode
in exactly the same bit rate as the x264 to insure you get a set of mpeg-2 assets that match in
quality. There is no guarantee that you will get exactly bit for bit quality, but you can come pretty close.
The tradeoff will be if such a high quality file will fit onto a standard DVD-5, which my guess is that it probably won't,
and you end up burning it to DVD-9 ( Dual Layer) to retain the quality."Everyone has to learn, so that they can one day teach."
When I'm not here, Where can I be found?
Urban Mac User -
@jerryj: need simple advice - what's the simple way to add subs and convert into QT format retaining at least good quality as the original. I wonder how to enocode (save) audio chanel 5.1 digital dolby not using Sorenson Squeeze or any high end transcoder you suggested???
video info: --------------------------------------------- output:
format: matroska (.mkv) ---------------------------- any QT format that can be burned with Toast or iDvD
video: h264, yuv420p, 1280x720 ------------------- any QT format that can be burned with Toast or iDvD
audio: ac3, 48000 Hz, 5:1 Dolby Digital ------------ would like to retain the 5.1 Dolby Digital
tnxLast edited by legionar2010; 29th Jun 2010 at 15:53.
Quicktime Player ( the non PRO version of Quicktime) has to be installed via the OEM System Disc .
On new Macs by default, it is not installed.
Follow these steps here:
http://support.apple.com/kb/HT3678
then go here to buy your Pro key from Apple:
http://store.apple.com/us/product/D3380Z/A"Everyone has to learn, so that they can one day teach."
Urban Mac User -
no simple way, my original answer to this is your only best bet.
The problem you'll need to let go of is the following:
retaining at least good quality as the original, and [snip]audio chanel 5.1 digital dolby not using high end transcoder
then you can simply:
1. Make sure Perian is installed on the Mac.
2. Open the .mkv in Quicktime Pro
3. Save as out of Quicktime Pro as .mov ( simply wrapping the .mkv in a QT .mov wrapper)
4. Drag & Drop this into Toast Titanium.
Toast will re-encode to 2.0 channel ac3, and when converting the .h264 it will
also burn in the subs. But that is your best bet with the tools you have."Everyone has to learn, so that they can one day teach."
Urban Mac User -
Use MKVTools
I downloaded a movie with subtitles.
Just select the movie and subtitles when you open the programme and it does it all for you. Convert to MP4 or AVI, up to you.
When I went to burn it with "Burn" a free Mac programme it converted to mpg and burnt to disc.
Then watched it on my television. All in all took about an hour.
Flawless. -
The problem though Nuttawut, is that the OP said he has to maintain:
* As good as quality as the original, meaning he has to have complete control over the encoding bitrate
* maintain the 5.1 surround sound
Your method might insure the second option, but even if he tweaks the xvid encoding in a two pass option,
it won't be as good as the h.264 encoded original.
So at best, your option just provides him another way of doing what I said, if he, the OP, can live with the trade-offs
of just getting it to a DVD and not be so stuck on maintaining a bit for bit quality encode."Everyone has to learn, so that they can one day teach."
Urban Mac User -
Hmmm yes.
In my haste to enlighten I forgot that bit.
I'm a bit of a stickler for picture quality myself, although sound doesn't bother me that much. After my conversion the picture looked good. Must say you would be hard pushed to tell the difference in quality from the original. -
hi terryj,
been on vacation these days, i'm back now. When i bought my MacBook Pro i faced with this problem about QT Pro i think i cannot install the QT7 on my mac. In instructions from apple are some notice like: Note: QuickTime X does not use QuickTime Pro registration codes.. But these link was posted in may 2010 so that gives me litlle hope cause i bought QTPro registry codes in 2009. I still have it. Do you know about these problem.Last edited by legionar2010; 15th Jul 2010 at 09:22.
hi
this is working great, need to upgrade my TT to version 10. Is any option in QT Pro to set up the encoding preferences for subtitles. I would like to set up an Central European (Latin 2) to get full slovenian font. Otherwise i get some of slovenian characteristics desytructed in subtitles, in Submerge there is an option but Submerge is for phone watching quality.
One more question: Do i burn these in 16:9 or 4:3 espect ratio, would like to get output in 4:3 without strecthing the video frame, or would be great 16:9 but without cropping or strecthing the video frame???
thanks guy for yours help especialy to you terry.
i'm loving this forum.Last edited by legionar2010; 31st Jul 2010 at 07:49.
also i noticed that some movies opened in QT player were subtitled with more than one subtitles instead of the map on my computer wich includes only movie and one subtitle???
second problem is that when i dropped the saved file from QTPro to Toast Titanium 8 it did not inccluded subtitles in the final writing. In menu set up was everything ok, but after checking the dvd disc on my external player i noticed that there are no subtitles, but quality of sound and video retained at least as original????Last edited by legionar2010; 1st Aug 2010 at 13:06.
How to add srt hard subtitles to mkv?
By warrr147 in forum SubtitleReplies: 11Last Post: 22nd Jan 2012, 13:47 -
Hardcode .srt subtitles to .mkv file without loss of quality
By bloodcell in forum SubtitleReplies: 3Last Post: 2nd Jun 2011, 23:28 -
Merging .srt Greek subtitles with .mkv
By wolfmandim in forum SubtitleReplies: 1Last Post: 27th Aug 2010, 01:44 -
Attachting SRT subtitles into MKV files
By Sukarestu in forum SubtitleReplies: 6Last Post: 15th Jan 2010, 02:07 -
Converting MKV subtitles to SRT
By Xpenguin17 in forum SubtitleReplies: 7Last Post: 9th Oct 2009, 16:59
