Im trying to rip a DVD contaning several titles
However all ripping tools can only find title nr 1
Is this infornation in the IFO files ?
Should i edit these files to remedy my problem ?
help plz..............
Results 1 to 9 of 9
Are you sure it has multiple titles ? Many (poorly) authored TV series have a single title and use chapter stops and playlists to allow the menu to address the disc as if it has many titles. if this is the case, rip the disc to your HDD using DVDFab HD Decrypter, then use DVD Shrink in Re-Author mode to extract a single chunk from the main title. Just drag the title from the right to the left hand pane, then right-click on the title and select the Set Start/End Frames option to isolate the section you want. Output this to a new folder and repeat for each "title".
Note : If you have AnyDVD running int he background then you could use DVD Shrink directly and do this in one pass.Read my blog here.
I did try to rip it, but i only sees one single title that is 2 mins long
The works fine on a standalone player. There u can clearly see that
it has several titles
But all the ripping tools only see one of the titles,
in other words, i cant rip it ................... -
you should be using vobblanker...rip it with dvdfab hd or anydvd in file mode, then open it up in vobblanker and use the main title in "cell" mode and you'll be able to see all the stops...u can blank all the ones u want or keep all the ones u want
I'm having this problem too; running HandBrake 64-bit Version 0.9.4 on a MacBook Pro.
I'm trying to rip the behind-the-scenes featurettes off of the Alien 3 Collector's Edition Bonus Disc (there are 11 featurettes, all are 8-24 minutes each), but of the 8 titles on the disc, only 4 are detected by HandBrake, and 2 of those are the featurettes I want (the other two are a bonus trailer and a short artwork feature).
These Alien series discs are pretty sophisticated, so it doesn't surprise me there are titles that don't show up on programs like HandBrake, but where are all of these other featurettes? What programs, on a Mac, can help me find and rip them? Thanks! -
Well....Handbrake isn't a "ripper"...it's an encoder/transcoder......and Handbrake does not remove any copy protections.
You'll need to rip the disc to your hard drive first, then pick off the pieces you need after that. The only ripper I know of for Mac is Mac The Ripper....but there are probably a few more. -
I'd have a look in the Mac section:
https://forum.videohelp.com/forums/17-Mac
RipIt may have taken care of the copy protection....not sure how up-to-date it is.
DVD is MPEG2 so "encoding" may not be necessary....especially if you just want to make
another DVD with just the pieces you want. "Encoding" lessens the quality...no ifs, ands or buts about it.
DVD Shrink and Twin titles
By Ronny G in forum DVD & Blu-ray WritersReplies: 12Last Post: 11th Aug 2014, 13:02 -
Convert DVD-titles zu mp4
By devilshell in forum DVD RippingReplies: 1Last Post: 15th Jun 2010, 03:23 -
DVD Architect - chainlink titles
By couchdirector in forum Authoring (DVD)Replies: 3Last Post: 28th Jul 2008, 13:13 -
DVD To MKV With Soft Sub-titles.
By blackjacka in forum DVD RippingReplies: 3Last Post: 24th May 2008, 03:12 -
Showing a series of titles on a DVD?
By Balliol in forum Authoring (VCD/SVCD)Replies: 10Last Post: 21st Jul 2007, 07:53
