    Oct 2008
    Israel
    Hi,
    tell me please:
    is it possible to convert a one loudspeakers video to a regular 2 loudspeakers video somehow?
    thanks.
  2. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    In what context? From a file? Or, are you talking about cables?
    More detail will help us answer your question.
    http://www.kiva.org/about
    Oct 2008
    Israel
    that's a video file, the sound comes only from one side (probably becasue of cables problem) . is it possible to turn it to 2 loudspeakers video?
  4. Member edDV's Avatar
    Mar 2004
    Try a different file that is known to be stereo. If that has one channel muted, then check your cables.
    Oct 2008
    Israel
    that's not my rip, and it happens only with that file.
  6. you can demux your audio, and make a "fake stereo" audio in audacity by copying the channel into a new channel (so both left and right channels are identical) , then remux into your video
    Oct 2008
    Israel
    thanks, thank you all.
