Is there any way to determine whether a VHS is NTSC or PAL?
Not by looking at the tape itself...no. If it came from outside of America chances are it is PAL.
It came from an American living in the UK :/
What will happen if I attempt to play it in the wrong VCR? e.g. NTSC in a PAL VCR? -
A PAL tape in an NTSC VCR will fail to lock.
If this is a single tape, take it to a dub house that does PAL conversions and ask for an NTSC digital file or DVD.
Or are you in a PAL region and can't play the tape? Many PAL VCRs made in the 90's or later will play NTSC VHS tapes as PAL 60 (525 lines/60 fields luma but with 4.43 MHz PAL chroma subcarrier). This requires a TV with PAL 60 support.Last edited by edDV; 27th Jun 2010 at 16:37.
http://www.kiva.org/about -
I am living in the UK. The VHS is most likely to be NTSC. I'm more concerned about damaging the VHS than any machine. VCRs are at least replaceable. I can't find any decent services to do transfers around here. So, I figured I'd do it myself. I guess I'll have to get a VCR that is both PAL and NTSC compatible.
Pls help! Best way to convert NTSC VHS (captured using PAL VCR) to NTSC DVD
By rairjordan in forum Capturing and VCRReplies: 33Last Post: 28th Nov 2013, 12:33 -
How to convert a PAL VHS into NTSC VHS or DVD?
By coody in forum Video ConversionReplies: 9Last Post: 22nd May 2011, 03:09 -
PAL-N VHS to ntsc dvd
By Paul99 in forum Video ConversionReplies: 17Last Post: 4th Apr 2011, 17:32 -
VCR is NTSC, but VHS is PAL
By joelson in forum MediaReplies: 1Last Post: 2nd Jun 2009, 09:21 -
Pal S-VHS to NTSC PC
By Jerry1964 in forum Capturing and VCRReplies: 14Last Post: 19th Aug 2008, 09:50
