Hi all,
I use AVCHD to rip & encode my bluray discs for my htpc and most of the time, it works perfectly fine.
However, I came accross the same problem for my last three br discs (lord of the rings trilogy). I can
rip m2ts files and convert them to mkv with makemkv, playing those mkv files works fine but whenever
I try to re-encode them with AVCHD, x264.exe.
I have downloaded the latest version of x264.exe but it doesn't help, still the same error. My mkv files
are made of a WVC1 video track and a Dolby AC3 track. Most of the movies I had encoded until now
were using a MPEG4 video track so the WVC1 track might be the problem.
Has any of you encountered the same problem? Any ideas of how I can solve this? I'm using Vista 64bits.
AVCHD? Do you mean AVCHDCoder?
I would probably try use ripbot264 to convert directly from the blu-ray bdmv folder.
BDRebuilder - x264.exe has stopped working
By kILLDR3n in forum Blu-ray RippingReplies: 6Last Post: 10th Dec 2011, 07:26 -
tsMuxeR.exe has stopped working
By stblob in forum Authoring (Blu-ray)Replies: 8Last Post: 7th May 2011, 13:24 -
Wavi.exe stopped working
By jcknecht in forum Blu-ray RippingReplies: 11Last Post: 1st Jan 2011, 15:24 -
By newpath in forum Video ConversionReplies: 6Last Post: 17th Jul 2009, 16:42 -
%APPNAME%.EXE has stopped working
By beardedboss in forum SVCD2DVD & VOB2MPGReplies: 8Last Post: 6th May 2008, 03:23
