  1. Hi have a Pionner DVR 640 - the dvd part is cactus- wont even read any CDs/DVDs - have tried cleaning the laser manually using a cotton wool bud dipped in 'Ethanol but still no go. I can get my hands on a DVR 630H - would the DVD in that unit fit in the DVR 640? so i wont lose any recorded programs on the hard drive in the 640H.
  2. Member Seeker47's Avatar
    Jul 2005
    Good question. My guess would be No . . . but you'd have to ask someone like Orsetto, for the definitive answer. The 63x series was problematic for a few reasons, and I believe that component (although it also does DL) may be different. I just saw at least one "low-mileage" 640 up on eBay, within the last couple days. It wasn't cheap either, but I'm glad I put aside a spare 640 (lightly used) back when I had the chance.
    Looking for Rare / Obscure / Hard-to-Find Films ? Check out http://rarefilmm.com/ , and also its Requests & Discussion forum http://rarefilmm.chatango.com
    Jun 2008
    Australia
    I believe this is the DVR-530H-S 630H-S service manual:
    http://www.filestube.com/db7608037aa6aa5b03e9/details.html
    You may like to compare the part number and interface type with your own.
  4. The burners in the x30 series are not compatible with the x40 series chassis and cannot be interchanged.
    The x40 burners are one-off oddball proprietary burners made by Sony, there is no way to replace them short of genuine Pioneer or Sony service centers, which will charge an obscene amount of money- it is cheaper to buy a new recorder. The final recorders marketed by Pioneer before they went out of the business were the 560 series and the LX series. Some stores still have stock of the Sony x80 and x90 series, which are operationally the same as the Pioneers except for lacking the DVD-RAM recording option.
    As seeker47 noted, the Pioneer x30 series can be problematical, although this is more of an issue with the North American units. If you live in a PAL country, and can obtain a good-condition Pioneer 530 or 630 at a good price, it can be a good choice. The USA/Canada 531-533-633 variants are a very bad risk.
