Has anyone updated to the latest firmware v1.2 for the Sanyo VPC-HD2000 camcorder? If you've, do you notice any difference before and after the update. BTW, is it possible to backup the original firmware beforehand? TIA!
I've updated to 1.2. At the time I had 2 Sanyo HD2000's around. One brand new with 1.2 installed and one from a friend with 1.1.
When I compared the two, the Sanyo with 1.2 had a quicker white balance adjustment and the colors looked more neutral, where the one with 1.1 had a much slower white balance adjustment and had a more yellowish cast.
Also the amount of noise when recording in the dark looked to be reduced with the new firmware (with noise reduction off). It did seem like the Sanyo with 1.2 preferred lowering the shutter speed where the Sanyo with 1.1 preferred bumping up the ISO.
I don't know how one could backup the current firmware, but installing the 1.2 firmware is very easy. Just make sure you have a good SD card, a charged battery and the power supply at hand. Reset your camcorder settings before and after installing the new firmware.
Sanyo xacti hd2000 firmware update
By frejk in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 20Last Post: 10th Aug 2010, 03:30 -
Sayno VPC HD2000 breif review and editing question
By Tom De in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 26th Jan 2010, 13:22 -
Sanyo Xacti VPC-HD2000 AVCHD Newb - Video Device Project Advice
By raverscout in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 8th Oct 2009, 09:37 -
Sanyo VPC-WH1
By Snakebyte1 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 23rd Jun 2009, 12:03 -
Video from Sanyo VPC-HD !000
By peterfb in forum Newbie / General discussionsReplies: 1Last Post: 13th Apr 2008, 07:39
