  1. I burn using nero, and tempeng.
    I can't get any video to display on the VCD, only audio.
    Sony NSxxx DVD player
    Jul 2001
    One Step From Hell
    Does it play on your computer?????
  3. nope, just audio
    i use windows medai player 8
    Jul 2001
    One Step From Hell
    Make sure your using the corredt templete(ie-NTSC,NTSC(FILM), PAL)
    In TMPG when you load the templete and hit start, make sure you can see the video playing while it is encoding!!!
  5. yup, I am using the right template NTFS(FILM) 23.9 fps
  6. I have the same problem. I have a divx file and used virtualdub to convet the audio and used tempeng for the video. i followed the directions on the how to guides and i burnt the cd and i get no video. I have tried all the templates and I can't get the video to play when i am encoding. The frame size is 448X192 and the fps is 20000. Any help would be useful. Thanks
