  1. I have some DVD's I encoded with Handbreak to MKV files. I am trying to mux them to M2TS with tsMuxeR and I tried PS3Muxer. Both programs gave me a shortened video file from 23mn 37s to 20mn 42s. In MediaInfo it shows the Duration at 23mn 37s on audio and video? I tried to mux with different frame rates but still haven't had any luck? The frame rate from the DVD was 29.97. Does anyone know how to fix this issue? I muxed other MKV files with no problem with PS3Muxer, then this issue came along so I tried tsMuxeR? Thanks for any help.
    MKV MediaInfo
    PHP Code:
    General
    Complete name
    C:\Users\***\***\Movies\Blassreiter\Blassreiter 002 The Price of
    Glory
    .mkv
    Format
    Matroska
    File size
    300 MiB
    Duration
    23mn 37s
    Overall bit rate
    1 774 Kbps
    Encoded date
    UTC 2010-06-12 23:04:50
    Writing application
    : [url=http://www.videohelp.com/tools/MKVtoolnix]mkvmerge[/url] v4.0.0 ('The Stars were mine') built on Jun  6 2010 16:18:42
    Writing library                  libebml v1.0.0 libmatroska v1.0.0
    Video
    ID
    1
    Format
    AVC
    Format
    /Info                      Advanced Video Codec
    Format profile
    High@L3.0
    Format settings
    CABAC           Yes
    Format settings
    ReFrames        3 frames
    Muxing mode
    Container profile=Unknown@3.0
    Codec ID
    V_MPEG4/ISO/AVC
    Duration
    23mn 35s
    Bit rate
    843 Kbps
    Width
    720 pixels
    Height
    480 pixels
    Display aspect ratio
    16:9
    Frame rate
    29.970 fps
    Standard
    NTSC
    Resolution
    8 bits
    Colorimetry
    4:2:0
    Scan type
    Progressive
    Bits
    /(Pixel*Frame)               : 0.081
    Stream size
    142 MiB (47%)
    Writing library                  x264 core 79
    Encoding settings
    cabac=ref=deblock=1:0:analyse=0x3:0x113 me=hex subme=
    psy=psy_rd=1.0:0.0 mixed_ref=me_range=16 chroma_me=trellis=8x8dct=cqm=
    deadzone=21,11 chroma_qp_offset=-threads=nr=decimate=mbaff=
    constrained_intra=bframes=b_pyramid=b_adapt=b_bias=direct=wpredb=
    wpredp=keyint=300 keyint_min=30 scenecut=40 rc_lookahead=50 rc=crf mbtree=crf=19.0
    qcomp=0.60 qpmin=10 qpmax=51 qpstep=ip_ratio=1.40 aq=1:1.00
    Color primaries
    BT.601-6 525BT.1358 525BT.1700 NTSCSMPTE 170M
    Transfer characteristics
    BT.709-5BT.1361
    Matrix coefficients
    Audio
    #1
    ID                               2
    Format
    AC-3
    Format
    /Info                      Audio Coding 3
    Codec ID
    A_AC3
    Duration
    23mn 37s
    Bit rate mode
    Constant
    Bit rate
    448 Kbps
    Channel
    (s)                       : 6 channels
    Channel positions
    FrontL C RSurroundL RLFE
    Sampling rate
    48.0 KHz
    Stream size
    75.7 MiB (25%)
    Audio #2
    ID                               3
    Format
    AC-3
    Format
    Codec ID
    A_AC3
    Duration
    23mn 37s
    Bit rate mode
    Constant
    Bit rate
    448 Kbps
    Channel
    (s)                       : 6 channels
    Channel positions
    Sampling rate
    48.0 KHz
    Stream size
    75.7 MiB (25%)
    Language                         Japanese
    Text
    ID
    4
    Format
    ASS
    Codec ID
    S_TEXT/ASS
    Codec ID
    /Info                    Advanced [url=http://www.videohelp.com/tools/Sub_Station_Alpha]Sub Station Alpha[/url]
    Menu
    00
    :00:00.000                     en:Chapter 6
    00
    :01:31.124                     en:Chapter 7
    00
    :10:05.121                     en:Chapter 8
    00
    :21:30.922                     en:Chapter 9
    00
    :23:11.106                     en:Chapter 10
    M2TS MediaInfo
    PHP Code:
    General
    ID
    1
    Complete name
    Glory
    .m2ts
    Format
    BDAV
    Format
    /Info                      Blu-ray Video
    File size
    327 MiB
    Duration
    23mn 37s
    Overall bit rate
    1 934 Kbps
    Maximum Overall bit rate
    35.5 Mbps
    Video
    ID
    4113 (0x1011)
    Menu ID                          (0x1)
    Format                           AVC
    Format
    Format profile
    High@L3.0
    Format settings
    CABAC           Yes
    Format settings
    ReFrames        3 frames
    Duration
    23mn 35s
    Bit rate
    951 Kbps
    Width
    720 pixels
    Height
    480 pixels
    16:9
    Frame rate
    29.970 fps
    Standard
    NTSC
    Resolution
    8 bits
    Colorimetry
    4:2:0
    Scan type
    Progressive
    Bits
    /(Pixel*Frame)               : 0.092
    Stream size
    160 MiB (49%)
    Encoding settings
    Language
    English
    Color primaries
    BT.709-5BT.1361
    Matrix coefficients
    Audio
    #1
    ID                               4352 (0x1100)
    Menu ID                          (0x1)
    Format                           AC-3
    Format
    Duration
    23mn 37s
    Bit rate mode
    Constant
    Bit rate
    448 Kbps
    Channel
    (s)                       : 6 channels
    Channel positions
    Sampling rate
    48.0 KHz
    Stream size
    75.7 MiB (23%)
    Language                         English
    Audio
    #2
    ID                               4353 (0x1101)
    Menu ID                          (0x1)
    Format                           AC-3
    Format
    Duration
    23mn 37s
    Bit rate mode
    Constant
    Bit rate
    448 Kbps
    Channel
    (s)                       : 6 channels
    Channel positions
    Sampling rate
    48.0 KHz
    Stream size
    75.7 MiB (23%)
    Language                         Japanese
    does it still play the entire duration without looking sped up? does the audio stay in sync? I've had videos playtimes get shortened before after doing a vbr encode but the video was actually fine...the program just didn't know how to read it I guess.
  3. Originally Posted by greymalkin View Post
    Thanks for the response. The demux video is shorter than the audio, so the audio is way out of sync. I can upload the original encoded mkv file around 300mb if anyone wants to see what they can do with it. Thanks agin for the help.
