Hello all, I seem to be having trouble with tmpgenc when I try converting my 700 divx file to mpeg. When I fix all the settings I click on start to convert the avi to mpeg and when its halfway done I stopped it and when I tried viewing the file, there was no sound. The video however was perfect. Question, is it possible to ONLY convert the video to mpeg and then extract the audio after and dub it over the mpeg? Another question, when I stopped the file, it was about the first 45mins of the movie and it was 1.4gb!!! If i did the whole movie it would be 2.8gb! I myself dont plan on putting a regular 100min movie onto 4 CDs!! HELP! I'm sorta new but I seem to be getting the just of this thing.
try and process the audio through virtual dub. just select "direct stream cop" for video, and "full processing mode" for audio. then save the avi. then encode it through tmpgenc. jus use the bitrate calculator to make ur settings right. virtual dub fixed all of my audio problems that i have had
TMPGEnc Video Master Works audio problem creating bd25
By necron99 in forum Video ConversionReplies: 0Last Post: 29th Apr 2012, 19:52 -
MiniDV Video & Audio Problem - Corrupted, Detiriorated, Missing Audio
By 4truce in forum Capturing and VCRReplies: 14Last Post: 4th Aug 2011, 06:36 -
TMPGenc Audio Problem
By Iwan2learn in forum Authoring (DVD)Replies: 5Last Post: 13th May 2009, 09:27 -
Audio Problem using AVISynth and TMPGEnc Xpress
By 1980sumthin in forum Video ConversionReplies: 10Last Post: 27th Jan 2009, 05:27 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 02:41
