Is there a DVD Audio Software out there that works with WINDOWS 7? (To put many music audio wave files on one DVD)
I have two soft wares - AUDIO DVD Creator and another that are fine with WINDOWS XP .........but neither works with Windows 7.
Thanks for your help.
tryin' bryan
Checking "AUDIO DVD Creator", it doesn't make real DVD audio, but uses AC3 or wave, so it is basically making a DVD video slideshow.
You can do this using GfD's "Audio Titleset".
http://download.videohelp.com/gfd/Help/AudioTitleset.html
You can use either wave or AC3 as your source -- easy to batch convert from other formats (or CD) using say CDEx.
Note: Use "chapters" rather than "titles" if you use more than 99 tracks. -
Alan HK,
Thanks.
I depreciate your advice and I tried this software. But it is far too complex for me. Is there any software that is simpler?
tryin bryan -
Sorry, that's all I know.
But to do audio titlesets is really easy:
1) Make a folder of wave or AC3 audio.
2) in GfD:
First, Settings (You only have to do this the first time):
Permanent/Authoring Engine/choose : Muxman/save
(-- this allows you to use Wave as well as AC3 audio)
and
AudioTS/(at bottom) choose "Default type for audio titlesets" as "Chapters"/save
Now start your project:
Insert/Audio Titleset
Click anywhere in the screen
Now you'll see a file selection box. Choose "source" your folder of audio (AC3 or Wave)
Click the arrows to move them all or individually into the list.
Click "OK"
Back to main screen
You can click File/Save as to save the layout, or just "Create DVD" button to make the VIDEO_TS file set.
Then burn in ImgBurn or whatever.
(Or preview if you have DVD player software, even VLC or MPC can do this.)
Spend an hour and read the documentation to add refinements like the background images, titles, etc.
What's the best software to make menu for an audio-dvd ?
By Theyodaddy in forum Authoring (DVD)Replies: 7Last Post: 18th Mar 2012, 18:58 -
VHS to DVD to PC has me stumped! Cant import audio to my software...
By jojokaa in forum Newbie / General discussionsReplies: 2Last Post: 12th Jan 2009, 09:58 -
What software should I use to extract DVD audio and convert it to mp3s?
By maccaneer in forum MacReplies: 2Last Post: 4th Sep 2007, 18:03 -
Audio DVD creator software
By bryankendall in forum Newbie / General discussionsReplies: 5Last Post: 17th Aug 2007, 14:45 -
DVD Audio Plays On DVD Software But Not On Windows Media Player 11
By CurtisMinBC in forum AudioReplies: 2Last Post: 29th Jun 2007, 12:39
