Hello!
I have an existing video stream with 24p (h264 for Blu-ray usage) and an existing audio stream (ac3 for Blu-ray usage as well).
The problem is that I don't have a tool to burn these two streams on a Blu-ray (without re-encoding).
Does anybody know a tool for multiplexing these two streams and burn it on a 24p Blu-ray (which actually meets the Blu-ray standard and is compatible with most Blu-ray players)?
Thank you!
lord
multiavchd to author , imgburn to burn
if your original stream isn't compliant, it will have to be re-encoded to make it compliant -
AFAIK both 23.976 & 24 fps [the actual film rate] are BD spec -- e.g. Sony DVDA & Roxio/Sonic MyDVD [which uses Sonic rather than Roxio code base], both have stricter compliance testing built in, & both work with 24 fps -- DVDA will handle either.
Maybe it'd help if you listed which muxing tools you're having prob with? tsmuxer? multiAVCHD?
3D Blu Ray authoring
By Shilar in forum Authoring (Blu-ray)Replies: 10Last Post: 8th Apr 2011, 22:28 -
Authoring Blu-Ray
By whoisquilty in forum MacReplies: 3Last Post: 13th Aug 2010, 10:57 -
Blu-ray Encoding and Authoring Help!!!
By jbandy1 in forum Authoring (Blu-ray)Replies: 7Last Post: 7th Aug 2010, 11:32 -
Problem: Final Cut Pro, taking a 24p HD Blu-Ray and making a DVD with Toast
By apollo1980 in forum Authoring (DVD)Replies: 1Last Post: 22nd Apr 2010, 09:03 -
HD Camcorders: all not 24p capable for archive direct to Blu-ray: thoughts?
By rjamesd05 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 12Last Post: 22nd Sep 2009, 10:49
