Hi,
I have recorder some HD files from the satellite but now I'd like to cut commercials.
What free (if possible) software can I use to do frame accurate cutting whithout reencoding the whole file ????
I'm looking for similar software that can cut mpeg2 (videoredo, tmpgenc mpeg editor,....)
I haven't used it but the latest version of videoredo supports h264 editing.
It's not free though.Originally Posted by videohelp tools page
I don't know of a free editor that can cut frame accurately. Most free ones that cut h264 only cut at I frames. If I'm wrong I hope someone corrects me.Donadagohvi (Cherokee for "Until we meet again") -
I have tried several of the free one's myself and none of them could do frame accurate cutting. Also you could also get freezing or pixelation of the video at the cut/join points and sometimes I would get AV sync problems after cutting out the commercials. Probably the best frame accurate H264 editor currently available is the Pre-Release version of VideoReDo TV Suite, but it's not free.
Most simple editors cut at I frames. I frames can be spaced from every 12 frames (DVB broadcast GOP) with half second accuracy to well over 300 frames (>10 sec) for many downloads.
Editors that cut inside the GOP for frame accuracy tend not to be free. The GOP must be decoded to frames for the cut, then recoded into pseudo GOPS (additional I frames) which may upset some players.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
Need to convert h264 avi to mp4 without reencoding, help?
By chupacabra24 in forum Video ConversionReplies: 2Last Post: 30th Oct 2011, 13:02 -
Editing H264 MPEG 4 AVC .ts files?
By grave101 in forum MacReplies: 14Last Post: 24th Nov 2010, 05:12 -
Are you able to insert blank video into hd h264 without reencoding?
By yoda313 in forum EditingReplies: 2Last Post: 6th Jun 2010, 00:42 -
VideoReDo now does H264/AVC editing
By VegasBud in forum EditingReplies: 2Last Post: 18th Jan 2010, 05:15 -
H264/AVC editing/stream copying
By pfxz in forum EditingReplies: 1Last Post: 11th Jul 2008, 12:25
